toyota pinion angle?
Started by Crazymays77, October 07, 2012, 05:49:14 PM
ok got the axle under the tracker set it where i would like it to be so i dont starve the pinion bearings. well it wont work there for the driveshaft. I got it in and all tacked up but it hits the strap bolts and wont turn. its sitting at ride height so the susp. cant travel at all or the driveshaft will bind even worse. so anyone know if i can angle the pinion more or will it just starve the pinion bearings. need to figure this out before tday for sure. I was thinking of pushing the axle back farther but i really dont want to do that i like it where it is.
nevermind i found a way to fix the issue without missing with the angle
