cab mounts and floor giving out
Started by tmspike, March 18, 2013, 02:05:57 PM
tmspike
Anyone ever redone the bottom of there cab because of the mounts and the floor pushing up. Just looking for ideas on what to do about it.  Just a bogger so it ain't gotta be fancy just strong.  The rest of the cab is solid so dont really need a new cab ??
u can put a plate in between or weld them on and drill a hole so they will hold longer
I used square tubing and made new supports on my old bogger.
85cHeavyMetalBogger
73chevytruck
Yup got the same problem. I'm just going to get a peice of square tubbing run it all the way across the bottom of the cab with the holes drilled in it for the bolts and weld it in place.
tmspike
