327 sbc out of 68 camaro 300$! sold! please delete
Started by Rapid Transit, May 04, 2013, 03:43:03 AM
Rapid Transit
i have a 2 bolt large journal 327 it is a complete long block from oil pan to intake out of a 68 camaro. it is a standard bore with 4 valve relief flat top pistons. it is all dissasemmabled i was gonna build it and decided to go a different route. block crank rods and pistons are all in great shape all it needs is bearings and gaskets and throw back together. dont have pics or numbers off the heads but they are just stockers and so is the intake can get pics and numbers off those if needed. also have a comp cams 490 lift cam i will throw in. asking 400 call or text eric 810-250-1790 for more info.
"it is what it is"     "wish in one hand p00 in the other see what one fills up faster"    "dose a bear p00 in the woods?" "not a zoo bear"
Rapid Transit
Stenner Stud
GoOd solid motor if I didn't already have a pile of sbc in the bern I'd buy this
Rapid Transit
Rapid Transit
Rapid Transit
