is a 700r4 good for my mud truck?
Started by redneckjones09, September 29, 2013, 02:29:04 AM
redneckjones09
is a new build 700r4 trans good for my mud truck with a sbc355 and sitting on 35s? with 3.73 gears?
Merc09
Its not bad. But id personally recomend a th350. 700R4 will definatly work. But from the things ive heard from other people and personal experience they arent super strong but if you want to go down the road you get over drive unlike the th350.
don't believe anyone that say's a 700 is weak.... If properly gone through then they are just as durable as a 350... I used to run a 700 when I had my 86 chevy longbox with a 425hp 383, 4:10's and 35 boggers and 38 tsls.
Now that I said that I would recommend a 350 or 400 for a dedicated mud truck, my reason for that is there's a larger jump  between 1st and 2nd in the 700 which means a larger rpm drop and loss of power when you hit second gear. If you plan to street drive more than bogg it then I'd go with the 700.  ==2cents
Quote from: Mudbuster on September 29, 2013, 12:47:32 PM
x2 his 700r4 lasted longer than a few of my 350th lol
Added to what was said above...............the 700R4 has a  lower first gear than the 350 or 400 turbos.
Quote from: 7387chevynut on September 29, 2013, 04:20:24 PM
that's why I said "there's a bigger jump between 1st and 2nd in the 700"
redneckjones09
okay yeah my bogger only goes out if its nice out or on big events. yeah the trans has been rebuilt and my motor maybe has 350 hp so I figured id go with a 700r4. so what yall are saying in a 700r4 the shift between 1st and 2nd r rapid.. where the shift in a th350 is longer?
not really "rapid" , you will have a bigger Rpm drop when you shift into second gear than with a 350 or 400 which your motor may or may not like if it's already in the truck I'd run it and see what happens you may be alright.
Theeee only reason I didn't "build up" my 700r4 is purely the fact that the parts cost a lot more.
But I beat on my 700, and never had issues. Stock weak 350 and 35s
fordrunner
I'm a ford guy the best gm trans I ever had was a 700r4 never did kill it
yukonjake
They aren't bad but people tend to lean toward turbo 350s and 400s but they all have there strengths and weaknesses,
redneckjones09
alright thanks guys I was just makin sure I was gonna be able to beat on it and have it reliable for this next year. cuz I ran a th400 for 2 years and I beat that thing and blew it to p00 in my other truck. ill try the 700 and see what happens.. I didn't know much about the 4x4 700s so thanks yall..  GotMud?
73chevytruck
If it don't have one already put a shift improver kit in it.
I put one in my 700r4 when I rebuilt it and it can be setup for drag race mode.
Been tuning my 700 for three years.  No issues.  But its built to p00 lol
JaketheSnake28
Iv got a rebuilt 700r4 4wd trans with shift kit and torque converter im looking to get rid of. Let me know if anyones interested.
Best thing you can do is put a big ole trans cooler on it...heat is the number one killer of any trans!
