rockwell steer axle boots
Started by 84silverado, March 18, 2015, 07:37:31 PM
84silverado
before this summer im going to rebuild my front axle, last fall I noticed my front boots had holes in them AFTER I went through a swamp. so its rebuild time. the question is though should I use the solid rubber boots or use the zipper type? I have the zipper type on now. also, I know Rockwell means money I get that, best place to get rebuild parts? bearings/races/seals/boots
thanks!
I went with full rubber boots,  my axle only needed to be cleaned, new boots, grease and oil, didnt need bearings, i ordered my boots from online, cant remember where, maybe ebay???
84silverado
How long have you had the full boots on? You have to replace them at all yet? Yea I don't need bearing but if I'm tearing is that far apart I'm just going to replace it and not worry
84silverado
JP Jagermudster
84silverado
Ive had mine for a while now, only 2 bogs on them tho,  so far so good
