How to section
Started by Kodiak450r, November 17, 2007, 07:47:59 PM
Newbie
do you guys know a place or maybe how to re arc the leaf springs.. mine on the front of my truck are looking a little un arced? lol sry if this isn't the place to post it.
HOW TO FIX A DRIVABILITY/PERFORMANCE PROBLEM ON COMPUTERIZED VEHICLES:
1) SCAN IT AND NOTE THE VALUES OF THE SENSORS.
2) REPLACE THE SENSORS THAT SHOW TO BE BAD OR REPAIR THE THINGS THAT ARE CAUSING THE SENSORS TO READ INCORRECTLY.
3) CLEAR THE CODES AND TEST DRIVE.
     All vehicles repond differently to problems, no two will act the exact same way although they can act similar.. Generally, the computer absolutely must be scanned FIRST and not as a last resort. You must know what the computer is seeing to understand why it is reacting the way it is. Once youve gone through all that, THEN you can go on to other things such as ignition module, fuel pump, etc. - CHECK THE CODES 1ST, AND HAVE IT SCANNED BY SOMEONE WHO CAN READ THE VALUES OF THE SENSORS. A sensor can be bad but not bad enough to throw a code!!
Merc09
