Car question
Started by Groundhawger, July 01, 2008, 12:40:31 PM
Groundhawger
we have an 01 chevy lumina, it has the 3100v6 in it. went out to start it one day, and it doesnt turnover. i have power everywhere. when i turn key on accessories, the security light is flashing. it never did that before. i thought it may have been the computer chip in the key was bad, so i bought a new key and it still doesnt start. i was told i can bypass the security system. does anyone know how to do that or have any other idea's? thanks GH
tcb
ilikebigtrucks
i am not sure how to bye pass the system but before you do that wwe had the same problem with my mom 91 lumina try cross jumping the starter and see if it starts we had to put a push button in cause some thing went bad between the key and the starter so just try and see what happens hope this helps and good luck
Econo-box from Hell
Turn the key to the on position and leave it there for about a half hour.  When the security light stops flashing turn the car off then back on.  If light stays on steady you should be able to start the car.
==nw geoo ==wn
i think un hookin the battery overnight would do it to.. mayB not
Groundhawger
im going outside to turn the key on and see what the security light does...i have unhooked the battery over night and that did not help
JeepinJohn
try locking the doors on it.then unlock them with the key.seen afew reset that way.just trying to help ya out.
==ggm
Quote from: Econo-box from Hell on July 02, 2008, 12:31:05 AM
if you  stand  buy the truck  you will hear a  clik ,  it will be  reset
Groundhawger
i jumped the starter and the car ran. im just gonna put a push button on it for now. on that kind of car..how do i run a push button starter?
Groundhawger
Econo-box from Hell
Have you tried what I suggested earlier?
==nw geoo ==wn
Groundhawger
Quote from: Econo-box from Hell on July 04, 2008, 02:57:48 PM
yep, i tried that. the light never stopped blinking. i left key on for 2 hours and still was blinking
Econo-box from Hell
Quote from: Groundhawger on July 07, 2008, 03:33:28 AM
At least you tried.  If you can find somebody with access to Alldata or Shop Key maybe they can print you off a copy of the reset proceedures.
==nw geoo ==wn
mr. goodwrench
put the key in the ignition and unhook the passlock sensor connector at the bottom of the column. It should be two little white wires with a orange shealth. Measure continuity across the terminals there should be continuity. If not the ignition sw is bad. I will bet money the wires are broken at the switch they always do. Only way to get ignition sw is through local dealer. have any more ?'s feel free to call me 231-250-6724
