Tach ???
Started by MR. Horsepower, July 17, 2008, 12:28:45 AM
MR. Horsepower
my monster 5" autometer started be slow reading up to about 2300Rpm after that its fine any Ideas or just can it  thanks ;D
==rocks fordd forddd forddgal ==roxx  LETS ROLL !!!!
check grounds,     wire con..  ==dunno   could  be going  bad
Quote from: DuneDude on July 17, 2008, 01:11:01 AM
what do you mean by can it
he  means  toss  it out  ;D
check connections to the dist.
more connectors = more resistance
Squirell
if you are running a aftermarket ignition like mallory or msd it happens to. you might need a tach adapter. my ignition burned the shift lite out of mine cause i didnt have the adapter
tach?? who needs one hold it to the floor and when it rev limits shift!
Bo Duke
Quote from: betterbeaters on July 17, 2008, 11:59:13 AM
DRIVE IT LIKE U STOLE IT!!!!!
Fraser
and if it has no rev limiter?
not to be dumb and ask, but is it calibrated for the engine your running? [the little wires on the back]
Econo-box from Hell
The tach probably has an issue with the needle touching something inside causing it to drag until it gets past the sticky point.
Does this tach have "Dave Gray" engraved all over it?  If it does I would sure like to meet the guy you bought it from.
==nw geoo ==wn
MR. Horsepower
Nope its not yours DAVE  sorry it must just be touching alittle caus the more you run it the better it works
Econo-box from Hell
Quote from: Bronco68 on July 19, 2008, 10:11:48 PM
I know, I just would really like to introduce myself the guy ripping off my stuff.
==nw geoo ==wn
