Whats your WHEELER?
Started by Bigdaddy, December 03, 2008, 02:41:25 PM
Wizzard
startin over...again
A Little  Ranger ;D    it  gets stuck every where  ==dunno
Squirell
93 wrangler with a 355/350/208 and with a 9.5" and a 10 bolt with 4.88 gears
75ish chevy cut down to 111 in wheel base 383 350 208 dana 60 and eaton 42s 4.56s lockers msd all that good stuff
soon to be on rocks with air bags and 53s-44s
and my 94 chevy with 4" and 33
mudpuppyracing
 Jeeps........................ One is yellow and one is blue.    Yellow one is 73' CJ-5 with a small block chevy and the blue on is a 2000 TJ with a big,big block chevy.  I also have a 83' CJ-7 that is not finished yet and a 97' TJ project in the works.      You know what they say............
Jeep tuff with chevy stuff!
Stock Sucks!!!!!!!!!!!  Pete............. oops
boggnass10
I,m a web wheeler  ya stay a lot cleaner that way
hope to have my S-10 done sometime in 09
95 S-10 468 BBC rear engine , dana 60 detroit locker, 14 bolt welded
456 gears, 203/205 doubler,400 turbo, 44 boggers,and 4 linked.
chetney
mudboggincrazy
80s s10 355 700r4  35swampers soon to have 38.5boggers and new frame and axles
Blazer frame with '86 chevy truck body on it, box shortened 11 1/2"....  on 44" Cut Hawgs
JeepinJohn
==ggm
Marion3
79 stepside 350 350 203  10&14bolt welded 4.10s 35 hawgs
jimmydean
  79 bronco.    booger green in color.   stock (for now) 460   38.5 boggers
blasterguy911
72 bronco 302 mild work done stock heads but its got cam new bottem end intake headers all the good stuff 44 front 9 inch rear
1972 bronco
bigdawg41
I'm stuck wheelin' two size 15 Wolverines right now. I don't like to beat up on my DDs so I keep it on the pavement. BUMMER!!!
MORGZILLA!
88 bronco. bone stock with some spiffy pink paint.
1979 GMC 1/2 ton 350/350 full time 203,  2.73 axle gearing with 29 inch super swampers.
derbydude
currently 92 ext. cab 4.3 5 speed stick[4 speed 2nd gear is gone] .
sanddude
a tired 93 jeep wrangler with a crapy 2.5 and 265x75x16 tire's  or 33's with ever i put on..
Sand rail   for street  / trail's  / dune's.
97 dodge ram 4x4  dodgee
06 Jeep wrangler jeepp
sand rail ==dj
