Straps or chains for haulin?
Started by Marion3, December 30, 2008, 02:36:11 AM
Marion3
Well what do ya use and why
ratchet straps or chains and binders?
i use  4  wrachet  straps,  because i could afford them,     but  i carry  chains and  binders  with me.
Squirell
i use two two inch wide ratchet straps
Ratchet straps are the most convenient but if I'm hauling something over 8,000 lbs. I use chains and binders.
I use 4 2" rachet straps, I feel there easier to use and less likely to come loose while traveling down the road.
JeepinJohn
got straps,but use chains,and binders.and put a lock on the binders handle,to keep it from coming undone.
==ggm
straps I only use 2 or 3 on in front and 2 on rear or 1 front 1 rear(if I am only hualing to a short bogg)
Marion3
anybody know where to get some chain for a decent price?
TSC wants 69.99 for 20 feet of transport chain
Squirell
chain isn't cheap. but try harbor freight they got some there
  i use straps :)
Quote from: Ranger Dave on December 30, 2008, 02:41:49 AM
Quote from: Mudbuster on December 30, 2008, 03:44:51 AM
Quote from: betterbeaters on December 30, 2008, 01:04:09 PM
Quote from: Squirell on December 30, 2008, 03:21:00 AM
TOMAC
all it takes is one bad bump.... i use chains on the back with binders locked and straps up front (3inch) with a light chain just because lol
whenever i haul something i hook a chain up front, get it as tight as possible, put truck in neutral go around back and use a chain and binder in the rear (you know its tight when the tires look like they have a load on them), then put truck back in park... never had any trouble.. and it looks better if you get pulled over.
chetney
Quote from: Marion3 on December 30, 2008, 02:13:37 PM
what size.. i sell chain at work
I use 2 2 inch ratchet straps hooked to an axle strap front and rear.
84Chevy
chains only way to go.. DOT love to see straps on heavy p00 going down the highway or roads
LIFT IT FAT CHICKS CANT JUMP
we use chains on the farm traps just dont hold up to a 5000# tractor from fallin forward on a trailor
straps   front   and   rear     and i haul fast
84Chevy
ALSO.... i believe technically you need one chain and one binder on all four corners of the vehicle... but thats just me, i use my straps.. to hold down my ramps or coolers, just paranoid that they will stretch and come lose
