Straps or chains for haulin?
Started by Marion3, December 30, 2008, 02:36:11 AM
84Chevy
We haul ugly loads daily! 2 chains 4 binders per truck... we use the big straps to hold lite stuff down.. hoods, doors, bs like that... i cant believe all the people that use straps, not safe IMO. More brave than i am !
LIFT IT FAT CHICKS CANT JUMP
Blake Scheuneman
aepends on what your haulin, light trucks are fine strapped down, rockwells and big blocks and trractor tires and transfer case combos start gettin heavy lol
chevv ==dew alll
i use straps and chains just depends wat i have but my truck isnt to heavy and i dont drive crazy...
85cHeavyMetalBogger
Quote from: BIG DOG on December 30, 2008, 11:26:15 PM
straps   front   and   rear     and i haul fast
bigblue81
CBakes
#65
 I tend to "over do it" and mega strap n chain mine down.
I use 2 Chains with binders and 3 straps.  Use my straps first to compress the suspension a bit, then chain the axles with front and rear with pressure. Once the chains are in, I'll crank the straps just a bit more. Seems to work. I did learn here though to use metal wire on my binders. Thanks for the info!
CBakes
Quote from: CBakes on August 07, 2011, 05:44:46 PM
1 more.
Now.. I would have to say that, That!       is a properly secured load..
CBakes
Quote from: Hammerlane on August 07, 2011, 07:31:29 PM
1 more.
Thanks, I don't like to mess around with potential trailering issues. I've seen some bad outcomes and don't want to be a part of it.
Boggerram87
#69
Quote from: CBakes on August 08, 2011, 08:47:47 PM
1 more.
4 Chains And 4 Binders Crossed Is Only Way My Truck Will Be Loaded Up....Even If Its A U-Haul loll
 4 chains and binders  and 1 safety chain on the front  i wire the binders shut     ive always put my chains threw the pocket and hooked onver the top always thought that was the way to do it  but i guess ill have to look into it  also make shure the chains ya use are in good shape no ground down links  and have a heavy enough weight rating  for what yer haulin
