What gears are you running?
Started by TopFist, January 13, 2009, 03:28:37 AM
camok10
#20
i got 273's and 32-11.50s on my k5 and i would love to have even 342's
84 c10 project
82 c10 beater diesel
Marion3
4:56 gears, Dana 60 Front  open.............14 Bolt FF rear w/spool
catfish
small 10 bolts front and rear 4.10 gears and rear spool in the s10
Squirell
i got 10 bolt front and a semi floater 14 bolt rear with 3.42's and a LS in the rear
solid 12
4.10's front & rear, dana 60 spooled and 14 ff welded, may change later if not enough gear
My samurai has stock axles with 373 gears. The rear is spooled and front is open. 6.5:1 low range T-case with 1.2:1 high, so it makes the 373's more like 447. With 35 x15.50 x15 swamper sx
4.10 welded 14ff rear... open corp 10 front ..
open 10  bolt  open and 14 ff true lock  with  5:13s  in the big dog
  jeep goin 60 frt  14 ff rear welded   4:10s
dd  2500 hd 4x4  4:10s
wife dd  durango 4x4 3:92s
Gearz
4:56 gears, Dana 60 Front w/Spicer locker, 14 bolt FF Rear w/ Detroit locker.
SteveP612
4.10's D44 open front 14FF welded in rear.  Will be different once I get the D60 for the front and 44 ince tires.
1997 Jeep Cherokee and 91 YJ
1995 S-10, D-60 open front,14 Bolt detroit locker rear,488 gears with 40 Hawgs
1978 Short box,D-60 open front,14 bolt leaded rear,410"s leaving and 513's goin in,44 Swampers
1974 Long box,D-44 open front,14 bolt welded rear,410''s 35 Swampers
2009 Dodge Challenger,364 gears with traction control.225/60/18's
4.56s dana 60 front eaton rear welded front detroit rear np208 on 42s in a week or 2 it will have rocks(6.72s) and 50" tractors!
Swampthing
Trail rider(purple jeep) 4:56 's toyotas posi rear limited front.
Little jeep(black cj7 with 48 terras) 5:57 open diffs
Swampthing(black scrambler) 4:88 posi rear open front
Green jeep(75 cj5) 4:27 stock axles
83 extened cab on 44 swampers 4:88 posi rear open front
Boggerram87
I just got lil guy axles.....10 bolts, 4.56's, detroit tru-tracs, its a combo rig so it sint to extreme
84Chevy
6:72 in my rocks on my old truck... new toys gonna have 60 front 70 rear with 4:10's till i get my 5:13's
LIFT IT FAT CHICKS CANT JUMP
