What gears are you running?
Started by TopFist, January 13, 2009, 03:28:37 AM
What gears are packed away in your axles? How about lockers or limited slips. And what axles?  Just woundering. I'm packing 6.17's. Dana 60's with a Detroit locker front and a spool in the rear. How about you?
Rollover Herb
6.72 IN MY  ROCKS  WELDED REAR  OPEN  FROUNT
==ogm
i sound like a p*(&^y , 3.55 but  gonna want upgrade to 5.13
Quote from: Captn. J on January 13, 2009, 04:08:06 AM
You'll be so happy.
Fraser
4.88 rear is welded, Dana 70 front and rear
creeping death
in my jeep (trail rig) i have 5.13's in a spooled d60 front and a locked 10.5 ff 14bolt rear.  ==rocks
ballistics-10
6.72 rockwells welding rear open front and a 203-205 doubler..
ballistics-10
#10
not as long as u think..maybe 6 inchs longer.. i can measure for u tommorrow..
That would be cool. Did you get it from offroad design?
91 k1500
5.38s open dana 60 front. welded 14 bolt rear.
91 k1500 with a dana 60 straight axle conversion, 14b ff rear, 5.38's 427 bbc th400 trans 39.5 boggers
Crazymays77
5.13 gears rear is welded and front is open. also have 4.24:1 gear reduction in t case. in 4wd low in drive i can go 15 mph at 3000 rpm's.
Oh yeah, you guys are gonna be sooooo jealous...
3.08's packin' 35's on 10 bolts!!!
IF, Heather convinces me we need to keep it instead of sell/ trade it, I've got plans for 5 tons with 6.44 gears turning 53" Michelins on the road and probably 50-60" tractor tires for play.
chevystudz7105
well just found out another lie that the guy i bought my truck off of.  said it had 4.10s front and rear. really it has 3.73's with a 10 bolt front and 14 bolt semi floater rear turnin 35's, but switching to these sense i have the axles already sittin out back...
10 bolt front with detroit tru trak and 4.10s, and a spool or detroit locker 14 bolt full floater.  eventually upgrading to 4.56's  or 4.88's depending on what i end up doing for lift and tires down the road.
millser
the 79 has rocks 6.72 i belive with 53 inch tire
the 89 has 14 bolt ff 10 bolt front 4.10 gears with 44 inch tires but a 60 be for summer
the 49 has 14 bolt ff 44 front 4.10 gears with 44 inch tires but 60 befor long
getting to many toys starting to cost to much $$$$
4.56's open front detroit locker in the rear with 42's or 35's which ever I decide I wanna use ;)
cj7on44s
MY JEEP HAS 5.38 WELDED FRONT AND REAR FORD 10.25 REAR CORP 8.8 FRONT, MY DADS SUPERDUTY HAS 5.13 WITH A LS REAR AND OPEN FRONT GETTING LOCKERS SOON. MY 2WD RANGER IS OPEN WITH A 4.10 8.8 FROM AN EXPLORER. IT SPINS THE 33'S A LOT BETTER THAND THE STOCK 3.55 DID
