got a question to ask you all
Started by 390JOE, January 26, 2009, 02:28:11 AM
rebelryder
you know whats cool about that video is that it took less then ten seconds for like 20 guys to get to the vehicle. thats why i love this club. if something happens you guys are right there in a hurry to help.  ==wgm rules.... now about doing donuts i agree that if you are in the middle of the pit you should be able to do them. you gotta think the guys going straight throught the pit kick tons of stuff out to begin with. plus when you are getting pulled out half the time you get stuff thrown at you anyways. just keep it away from the spectators and other trucks.
ufwda.org
big red
Quote from: Mudbuster on January 26, 2009, 11:04:31 PM
I do it on occasion but I make sure I'm not real close to others, I say it's OK as long as the persons using some common sence but If they're not then by all means say something before someone does get hurt. ==2cents
common sence will almost always win
dozer man
 Duh  a little " Common sence " goes along way.  Its a dangerous sport, so p00  has and will happen, beets living in a bubble tho
duel1985
you all make good points saftey first i do them away from crowds but we all fail to remember any thing your tires will grab and throw still can go anywhere just be carefull GotMud?
Jr
is that the same samauri that alvin has(mudduck)
Quote from: JR. on January 05, 2010, 05:11:02 AM
Yes I'm pretty sure it is but some things have been changed.
just a note, if you look at just about every pic on this topic where someone is throwing mud, no one is visibly close...I think you all have set the example.  applaudd  common sense.  nuff said.
woody11769
Quote from: TBigLug on January 29, 2009, 11:25:46 AM
I don't see a problem with it. If you can't stand to be around spinning tires, you probably shouldn't be at a mud bog to begin with. I'd say they're fine as long as they keep it away from the crowd enough to not risk sliding into them. Say 100 feet or so.
X2
