rear shackle flip question
Started by bulldog, January 29, 2009, 09:03:55 PM
bulldog
if you flip the rear shackel how do you get the front level. I have a 86 suburban with 6 inch lift i want to fit 44s.I have 37s now just seeing what i dont know thanks for the help.
91 k1500
you talkin about the front of the truck or front of the spring?
91 k1500 with a dana 60 straight axle conversion, 14b ff rear, 5.38's 427 bbc th400 trans 39.5 boggers
bulldog
Just what to know how you get the front of the truck level with the rear after the rear flip
chevystudz7105
i wouldnt recommend doing this and im nto sure why im mentioning it  but if u wanna go cheap but its alot less safe put blocks in the front.  if its a muddin truck only and will never see the pavement  then it may be ok to put blocks in the front but i would not go over a 2 or 3inch block at the most.    got a buddy that put 2in blocks in the front of his truck to level the truck out a lil and he hasnt had any problems.
Boggen Joe
change front springs, rear flip will give ya about 5 1/2 in of lift and more artulation
bulldog
so 12in front springs would be the thing to do with a rear flip and thanks for the helpfull input
thats your best option, not your only one..
with that amount of lift you will create new problems that will need to be addressed
ie..
driveline angles
latteral movement of axles
Breakage
good luck.
TOMAC
when you do the rear shackles makes sure there angled back a little too.
6+3 lift with 44s
you can turn lock to lock but when you hit a bump bye bye fender
bulldog
OK thanks for all the input guys one more question.I dont have much money so if i live it with just 6in lift and 3in body. Whats the biggest tire i could run with out rubbing to bad
You into wheelin.. or bein pretty??
I've got 40's with a 4" suspension lift, but I had to cut sheet metal... looks like sh**.. but I'll wheel the he** outta it.
TOMAC
Quote from: bulldog on January 31, 2009, 09:32:47 PM
i say stay at 40s
bulldog
i love wheeling but just didnt what to hack the sh!! out of my truck so ill go with 40s thanks for the help
