203 question
Started by 88chevy, January 30, 2009, 06:09:11 PM
88chevy
I have a 1987 chevy with a 203 and its got the part time conversion kit in it.  Well i only have one shifter for high and low, for 2 wheel and 4 wheel i have to crawl underneath and move a lever.  My question is am i supposed to have two different shifters in the cab or just one?
 one in the cab 2 linkages under it hooked to the shifter
88chevy
yeah but with that shifter i cant put it into 4 wheel drive only go from high to low
idk if i have the wrong shifter or what
are you sure the shifter is working right?  I dont think you could pput the wrong one on....   but if its not hooked up right or out of adjustment that could be your problem..... I have had a few trucks with 203s and I have aways had a shifter problem with a parttime kit... (they pop out of gear) but I found a few different way to stop it...
88chevy
ill look when i get home
by the way how did the 87 chevy get a 203? I thought they ran a 208
88chevy
it did but the guy a bought it from blew the tranny so instead of getting it rebuilt he pulled the tranny and transfer case out and put a 203 and a new tranny in
if it were me I would get rid of the 203 and go back to a 208 or 205..... 203s are junk  only good for scrap! (I have scraped 6-8 of them)
88chevy
i want to put a 205 in it but i dont have the money right now, gotta get some little things fixed first
ok thats cool if you only play with the truck put it in low and ziptie the linkages in place that one of the ways I did it
88chevy
thats a good idea thanks
  STOP BY   I GOT 2   SETTIN NEXT TO THE GARAGE   I FROM A 350  AND 1 FROM 400 TRANS  SAME LINKAGE         IF YOU IN NEED   OR WANT TO COMPARE   OR SEE WHATS MISSIN     CLYDE
Quote from: 88chevy on January 30, 2009, 07:23:57 PM
Right there is your problem I'm sure...........  Did he change the shifter also or did he use the one that was ment for the 208 ??? The 208 shifter mounts to the floor of the truck and only has one Rod hooked to it.  The 203 shifter mounts to the end of the tranny and has 2 arms on the bottom of it for the rods to hook too.
I'd be willing to bet he just made the 203 linkage hook up to the 208 shifter so he wouldn't have to deal with the 203 shifter.
As betterbeaters said the 203 shifters are natorious for not working right they need to be lubed constantly...
