tire-gear ratio question
Started by Boggerram87, February 05, 2009, 09:49:27 PM
Boggerram87
I know that you aint suppost to 2 diffrent size tires front and rear or it will screw up the transfer case ratios (35's on the front 37's on rear) or side to side with lockers, but if I wanted to run a 35x12.50 on the front and a 35x14 on the rear that shouldnt throw my ratios off should it? Seams like only height would effect it.
dont matter as long as theyre the same height
Boggerram87
Ok thanks, i figured as much i just wanted to double check so i didnt blow anything up!
