Clevise or Hook??
Started by frdboy86, February 15, 2009, 03:32:59 PM
frdboy86
I dont have a receiver yet  and I would like some retrieval points.  Do you think it would be ok/safe to weld on a hook or clevise?  maybe even bolt on??  Im a pretty good welder   i would like some others thoughts.
Crazymays77
i would get some weld on d rings. then use a clevis to hook the strap to the d ring. that way it cant fall off or slip off and go flying. make sure you weld them to something solid.
Quote from: frdboy86 on February 15, 2009, 03:32:59 PM
best bet is to use a closed loop design, not sure I would weld a clevis (heat would weaken the metal)
depends on the vehicle, weight, design of pull point, nature of the stuck etc... read around in here
there are several topics that cover this.
weld some thick u boults on the frame and get a clevis to go on tht for the strap
I'd put on a reciever then put a clevis in it.
millser
frdboy86
well see thats the thing...right now i dont want to spend the money on a receiver.  i wanna focus more on makin it run good and drive good.  I got some hooks and clevises sittin around thats why i asked about welding a couple of those on.
safty should come  frist.      everyone  just  saying  you should  have good  pull points before you go get stuck.
whats the  with of your  frame,   maby  someone  has  a  used  hitch laying around  they can sell you  cheep.
i have a reese hitch off a  ranger,   28" inside  32" out side.  ill  get you  cheep  if it will fit.
ranger dave it for his bronco 2 arnt they the same a ranger and bronco 2?
Quote from: Ranger Dave on February 16, 2009, 01:47:05 PM
x2 make it safe first.
I don't care who you are you're gonna get stuck at some point and how would you feel if your hook point let loose and hurt/killed someone. make a post in the wanted to buy section I'm sure someone on here has a hitch that'll fit your rig and won't charge you an arm and a leg. Good luck
Quote from: burl on February 15, 2009, 05:04:59 PM
==doh ==doh nonoo ==no nonoo ==doh ==doh
you only have 1 time here on earth, no second chances, Safety 1st    get u a receiver.... JMO
x3
Quote from: millser on February 16, 2009, 02:50:34 AM
Quote from: TBigLug on February 15, 2009, 08:30:46 PM
x2 ==no
Quote from: Hammerlane on February 16, 2009, 05:48:08 PM
Quote from: burl on February 16, 2009, 03:34:33 PM
its  off a  ranger.   it  mite  fit  his  bronco 1I    thats  y i offer it. for  $25 dollars.   i don't  want  no clevis  or  anything  flying  at  me.   or anyone else.   i want to be wheeling next week to ;D
frdboy86
PMed
Quote from: Ranger Dave on February 16, 2009, 06:44:03 PM
come  get it.  its  yours.
frdboy86
I have a receiver now....Thanks again Ranger Dave.
your welcome,    be  safe
Mudlight
just to keep in mind there is alot of people including my self that will not hook up to some one with a hook,i've seen them break,just my 2 cents
==nw forddd  ==wn
frdboy86
Thats alright now.  Ill have a receiver in back.  I just dont know about the front now unless i can fin something from the scrap yard
Quote from: Mudlight on February 23, 2009, 10:48:31 PM
