shifting hard
Started by Corey, February 19, 2009, 03:09:11 AM
Corey
I recently bought a 99 gmc sierra and yesterday i noticed it started shifting hard into 2nd gear and a little bit into 3rd, and will clunk sometimes (sounds like the u joint) I checked the fluid and its all good and doesnt smell burnt or anything. I dont even know where to start..... any ideas?
tv cable, body lift on it? linkage might be outta whack on it. gov stuck? what trans? 4l60e?
Corey
its all stock, if the cable was messed up wouldnt my other gears be off too? and yea its a 4l60e
BadF-150
try changing the filter because it may be getting plugged up and just bad fluid in general
good point. i was thinking it was older i guess i dunno
Corey
Quote from: Crazy4x4StepSide on February 19, 2009, 03:44:18 AM
im gonna give that a shot soon
Corey
well i replaced the tranny filter and u joints... still doing it also its vibrating pretty bad at about 55
4x4ZR2
my brothers truck does the same thing....same truck. hes got a warrenty so geuss it goes to the shop when he gets back from cali.
==nw chevv ==wn
Quote from: Corey on February 23, 2009, 12:55:29 AM
Vibrating is not good...last time I had a tranny doing that it turned out to be a crack in the TQ converter.
johnolia
there may be a rebuild in your future thats all i can really say without looking inside the trans
1992 f150 302 with flowmaster 40 series
Corey
well i had the tranny guy at work drive it and hes gonna tear it apart for me and check it out.
Corey
well its sittin up at work right now gettin worked on hopefully its nothing too major
mlankton
A friend of mine  had a 96' silverado and his will periodically clunk into third gear. He replaced all the u joints checked tranny mounts etc. Then he took it In to a tranny shop they went through the whole thing and charged him 700 dollars and it still does it. It's been doing this for about 5 years and no problems just turn up the radio. LOL the vibration is probably a different story. I would check the driveshaft for a bent conditon or dents missing balancing weights etc.
Corey
got it fixed the other day.. it was the spacer plate.. dont really know how it works or anything but the little ball that falls into the hole had reamed itself out so it created its own shift kit.. he fixed it for dirt cheap so im happy
