94 jeep cherokee . Neutral safety switch bypass
Started by JaiDeeEmm, March 02, 2009, 04:53:05 AM
JaiDeeEmm
So my saftey switch is shot and i want to by pass it .. can anyone help me out here?
yes but need more info on  jeep. what tranny do you have. also is this your dd or wheeler?
JaiDeeEmm
Its just the wheeler,  im not so sure what trans its got. Im pretty sure there is two auto trannys for that year.  hmmm if i take a picture will it help anyone
no need just look on the right side of the tranny. if there is a set of wires going into a triangle looking box then you have a 4 speed and that can be cleaned out and that might be the problem. check this site out and read it. it shows you what the switch looks like and how to take it apart and clean it. if you have the 3 speed then just bypass it. let me know which one you have then i can help you.
http://www.cherokee-jeep.com/1-2swremov.htm
JaiDeeEmm
i have the four speed. Looks like ill be taking it apart and cleaning it. THANK YOU!
ok if that doesnt work then i can help you bypass it. your not far from me so it would be better to stop by and show you. easier then trying to expain it.
JaiDeeEmm
JaiDeeEmm
the thing is so gummed up on the inside its unbelievable..   Half the threads on the arm that hold the nut in place broke off. :(     so does your way of bypassing it need to half a complete unit?
not sure mine is still there i didnt feel like cleaning it out since its a wheeler. we can just try it. put it back together and on the tranny then i will come down when i can. pm me your address and number.
JaiDeeEmm
Well i guess i have to add. I will be road driving this on weekends.  I have read into it a bit and i have found you can connect  pins b and c together  and it will work. But it is also saying that the switch has more functions than just being a neutral safety switch..
JaiDeeEmm
So what im seeing i might be better off getting a junkyard one and cleaning it. ?
really i didnt know what. what i did is connect b and c together on the side before the connector then plugged it back in. i dont know if that will work since your is broke
just try it. u can bypass it either way but just becareful when you start it.
yeah you can do that. dont buy a new one there 240 bucks
JaiDeeEmm
Ill see how much the local junkyard wants for one.. I guess theres a yard around here with about 100 cherokees. Parts have to be cheap?  Ill even take it apart and clean the new ( used one ) just to be safe..
one thing i just read about. My reverse lights dont work and that is another symptom of the NSS
Anyways. If i need any help ill let you know.. Unless you want to help put floor pans in on my jeep when it gets a little warmer ? haha
i might be able to help. check with s&s auto there on field rd.
JaiDeeEmm
exactly where i was going to go. Thats within 5 miles of me .  You guys on this site are awesome glad i joined
no prob thats what we do. while your there check and see if they had manual doors for a 88 xj 2door. i have the power windows and i hate them. dont work that good. if you can get a price too. thanks
JaiDeeEmm
well bought  NSS for 10 dollars and it was almost new ! woot!.     No 2 doors at all. Sorry
ok thanks for looking. let me know how it goes
