Dodge Ram Wont Start!?!? NEW PROBLEM DETAILS on page 3
Started by A.J. Hall, March 10, 2009, 06:30:15 PM
A.J. Hall
Dangit. :( how do I get one of those? can I rent them?
Buy American and not that stupid foreign Toyota crap. That would make you a true American.
mudbrat71
your best bet is go to a local repair shop pay them 50-60$ to diagnos it properly  then fix it your self i have a lot people do that at my shop  it dont take long to throw that much in wrong parts at it . my  snap on modis scanner was $10,000
A.J. Hall
I got 10K. where can I buy one lol
ride n dirty
A.J. Hall
I changed the plugs and coil and got the truck to run for a second and it through two codes and it said the crank sensor was malfunction :/
Norm Henderson
get rid of the dodge and get a forddd loll GotMud?
Drive It Like You Stole It
A.J. Hall
Ford or chevy lolz.
So I have replaced the Crank sensor, cap, rotor, plugs, and coil and nothing helped. I am going to try the Idle/Air Control valve and see if that helps.
Norm Henderson
have you checked your fuel pressure?
A.J. Hall
I just replaced the IAC Valve and no change. :(
I did not check the fuel pressure. But I did pour gas in the throttle body and I can smell gas after crankng. Its getting plenty of gas and spark.
Norm Henderson
A.J. Hall
Quote from: lilwagon on March 13, 2009, 01:39:53 AM
plug wires?
should still start and run a little plus they look pretty good.
ride n dirty
 did you check for spark, sorry autozone checked my cps for a grand am thought they would be able to check yours too
Norm Henderson
did you try kickin it? and if so how about talkin dirty to it?
A.J. Hall
Quote from: ride n dirty on March 13, 2009, 06:07:13 AM
Its cool thanks anyways for the help.
A.J. Hall
Quote from: lilwagon on March 13, 2009, 09:11:30 AM
I have tried kickin it a few times. Maybe I should try talkin dirty to it. It just feels like cheating cause I only do that to my Trans Am :(
Im gonna try cuttin off the cat.
MrCompton734
There is a very easy way to check codes, if I remember right. You turn key to ignition and turn off like 5 or 6 times, and then it will blink.
check this,  more in depth
http://www.allpar.com/fix/codes.html
That led me to find a TPS sensor was fxxxed and so was the o2 sensor and some other shiat.
Dad, I'm twelve.
A.J. Hall
Thanks I tried that also. But its only for 97 and older cars/trucks. :(
MrCompton734
Quote from: A.J. Hall on March 13, 2009, 06:08:48 PM
Sorry didn't know, if you were closer I'd bring my dad's code reader to ya. He's got a code reader. Wish I could help more :(
Dad, I'm twelve.
A.J. Hall
Its alright but thanks anyways for trying.
MrCompton734
Quote from: A.J. Hall on March 13, 2009, 10:14:03 PM
Ummmm tps sensor made it so my truck wouldn't run, did not throw codes either. Do you have an alarm? Buddy had same exact truck as you, and his alarm malfunctioned and wouldn't let his truck start. So does it start at all now, or just no idle? I'm not a genius, but I am very good at searching the net for info.
Dad, I'm twelve.
