jb weld ?
Started by mudslayer2008, March 21, 2009, 03:17:54 PM
mudslayer2008
 can you jb weld a piston ???  do you think it would hold ???  it is just alittle part of the side at the top.
it might work but would not do it cuz it gets really hot in there and i dont think jb weld its made for high heat. just my thoughts.
won't work don't even try it ==2cents
I wouldnt try it.  Better off changing the piston,
I second all above stated opinions!
the harvester
i will third fourth and fifth all of the above opinions for the price of one piston i dont know why you would even consider it
Bo Duke
na it will be fine...lol run it!
mudslayer2008
Quote from: the harvester on March 21, 2009, 04:57:19 PM
can't find a piston and summit wants $238.00 for one. probally wont try it but, it was a thought what can I say i'm a redneck tech.
      by the way it is for a 460 bbf if anyone has one.
Bo Duke
Quote from: mudslayer2008 on March 21, 2009, 05:14:30 PM
junk yard?
mudslayer2008
the ones that r open on saturday's don't have anything.  I was hoping to get this done and running this weekend.  If it wasn't for bad luck I wouldn't have any luck at all.
the harvester
go to  a local engine shop and try there dont pay the money summit wants someone has got one cheaper i promise
Kodiak450r
you can buy a brand new piston from summint for like 50 bucks i found one here http://store.summitracing.com/partdetail.asp?part=TRW-L2404F30&autoview=sku
the harvester
i thought 238 seemed high
mudslayer2008
Quote from: Kodiak450r on March 21, 2009, 06:17:28 PM
thanx I'll want to check around locally first, but I got the $238.00 out of the summit book a budy gave me must have been hi-performance or something.
You could try tig welding the old one...that would depend on what is exactly wrong with it. If it just has a little chunk out of the top I would try it and then machine the weld with a dremel tool or something.
Bo Duke
Quote from: Disturban on March 21, 2009, 07:47:52 PM
Not saying u cant but be careful if u do, u might throw the whole motor out of balance and just rattle it self apart again....
mudslayer2008
a buddy just called me I can get a new oem replacment for $29.00 + tax on monday.
so does n  e  one know about how much it cost to have a wrist pin pressed out and put in a new piston head ???
shouldnt be that muxh to do that i would say less than 20 bucks
I wouldnt put it on a piston but JB weld will hold to Exhaust heat.   I filled the A.I.R. injection ports on a Exhaust manifold on  my sisters old Bonneville with JB weld , let it set up 24 hours, worked for years with no leaks.
It was a 400 Pontiac motor , it put out alot of heat and it did last a long time!
