amc 360 timeing off
Started by Adrenaline Rush, March 21, 2009, 08:21:53 PM
Adrenaline Rush
anyone mess with the timing on a 360? i moved the distributor and it helped some and messed with the idle screw, but i still have some popping at 3000 rpm, and the motor shakes like crazy when i shift it in 2nd or 3rd at low rpms. never did it before. i know the timeing for this motor is 10b but it seems to get better at 20b. should i keep turning the dist.cap to make it better? im so confused... need help.....
<br /><br />,[____l,<br />_ -o==o-_ <br />) ()_)¯ ()_)
mudslayer2008
have you checked your timing chain and gear they could be worn and the chain could sliping at high rpm's just a thought.
when I tore down my 460 you could almost take the timing chain off with removing any of the gears.
Bo Duke
check ur firing order and ur spark plugs could have a wire backwards.....
MR. Horsepower
how old is the motor sounds like it might have a lobe wore off the cam
pull  number one  spark plug out,  bring up comp. and  set on 0    check your  timing.  see if  it  jumped time.     fowled  plugs,    could  be  many things.   is  it a points  dist.   ==dunno
Wizzard
i've had a few of those old rambler motors...  360 were know for the timing chains. also pull you dist. and look at the gear on the bottom and see how sharp the teeth are.
startin over...again
Adrenaline Rush
ok i will try some of this out and let u guys know what i see. thanx for the info!!! damn i got to get it fixed for gladwin.... i better hurry
