dana 44 front axle ?
Started by mudslayer2008, March 24, 2009, 05:47:19 AM
mudslayer2008
I need to change the u-joints in a dana 44 front and was wondering if there are c - clips holding the axle shafts in the differencial or if they are ff axles ???
Full floaters of sorts...But after you remove the spindles the shafts will pull out.
Bo Duke
IFS or Straight? My IFS has the C clips.....
mudslayer2008
straight axle it's a 79' bronco
pull of tires, caliper, lockouts, hub assembly, spindle, should be 5(?) boilts on your ford.... GENTLY remove spindle, grab shaft and pull. should come right out no problem :)
mudslayer2008
thanks for the replies   there alot of help.
mudslayer2008
can n e one tell me where the axle seals are in the front axle.
r they out towards the spindle or are more in towards the diff.
Quote from: ToughBowtieTruck on April 08, 2009, 01:25:50 AM
Quote from: mudslayer2008 on April 08, 2009, 01:22:48 AM
near the differential
you would have to remove the carrier to change them
