trans question
Started by chevy599, April 02, 2009, 10:50:07 PM
chevy599
i pulled the trans on my truck today to swap it the trans in it has a real long shaft than like a 2in plate that goes between trans and transfer case... i got a extra trans but the tail shaft is too short... is there anything i can do about this or does someone know where i can buy one
chevv chevgal chevvv ==rf ==fo
change the  tail shaft, or find someone that can, or get differnt trany.  what trany is it ==dunno
Like Dave said what's the tranny and what's the tcase ???
chevy599
tranny is the 350 turbo.. im not familair with changin the shaft or else i would have done it ima tear apart the trans and see if i can figure it all out tomorrow if not that i dont know places charge too much to do that stuff kinda low on money
That's what I thought the spare you got is probobly set up for a 203 tcase and the one in the truck is set up for a 208 which uses a 2wd shortshaft that has been cut down. The 350's are a pretty easy tranny to go through but if you've never done it before then I would recomed that you get a good manual first.
chevy599
the one in my truck right now has where the driveshaft slides in the tcase the rear driveshaft.... the spare has where i need to use a u joint to hook up rear shaft... how do u know which tcase is which.....also i cracked 2 bi pieces off of the bell housing
If the tcase is all aluminum than it's most likely a 208 if it's cast iron then it's either a 203 or a 205 and the safe bet there would be the 203
