Kill Switches
Started by Ranger Dave, June 02, 2009, 12:39:10 PM
rebelryder
i think everyone should have a main shut off on the rear of the bogger somewhere. out of the way of mud and water and what not but easily accesible in case the driver is knocked out and no one can get into the truck to hit the toggles.
ufwda.org
73chevytruck
no i didnt, but after the trucks all fixed its going to have a main shut off, on the drivers seat by the floor
Bo Duke
Quote from: rebelryder on August 21, 2009, 09:30:59 PM
I agree, on the back bumper is the most universal place i've seen painted a bright color.....
headache
im trying to wire up a push button ignition in my 76 ford but im not sure how to do it, people have told me so many different things but nobody can  tell me  one certain way, can any help?
the   small  wire that gose to you  cycloined,    your putton  goes in that.   cut in half and  run one wire  in and  one  back out.
Quote from: headache on November 03, 2009, 11:42:07 PM
bowtie482
Main kill switch is a must.
If it breaks, build it better and beat it some more
my Jeep is set up w/ chevy stuff, but you can use the same theory..
batt + to a master switch/solenoid
2 small wire + from the master switch to a circuit breaker or inline fuse. 1 to a kill switch and 1 to pushbutton..
from the kill switch to the coil
from the pushbutton to the start solenoid
its real easy to do and not complicated..
you will need..
heavy guage wire (batt to master switch to starter) #4 weld wire will work fine
small guage wire (master switch to start button and ign. switch)
master switch - needs to be able to handle some amperage
ign. switch - the red racing type switch (kill switch)
push button switch
various eyelet electrical connectors
2 in line fuses or circuit breakers
bout' 2 hours time to put it all together.
bigdawg41
Just starting on building my rig, but since i got it without an ignition key anyway and pulled the cylinder out, i planned on push button start and master kill switches inside and out.
mike 64
yup.. main kill
fuel pump
ignition all toggled!
gmcc Its not what u buy... its what u build!! chevgal
pontiac223
same her this way i dont have to worry about theft
Bubba530bd
yep ignition and fuel pump on switch power disconnect between seats
michevyfreak
ignition kill and a cigarette lighter for a starter switch.  want to put a main kill on it soon
MUD HUNTER
One on the dash... and one on the a$$...
They're cheap, easy, and silly not to have one IMO
mark48420
always nice to have kill switch especially if it has chance of wheels going over the top and the roof being bottom
KHP8ntballer
Im working on a dash touch screen for my rig that will have a touch toggle for every system in my truck. It will also have regular toggles off the bottom incase the screen fails.  On the top it will also have a push button power and kill switch just like on construction equipment such as lifts and such.  That will be mounted in te cab and then the rear of the truck will have a pull kill switch.  Like said above, they are so easy to make and almost a must.
Everyone needs a smart button somewhere and a proper FIRE Extinguisher ......
http://www.hanford.gov/fire/safety/extingrs.htm
i know everyone thinks never happen to me but sooner or later it could so be prepared  ==wgm
'the DON'
i have key and switches on ign and fuel. if you dont have one try and wait until its to late . im glad dave built his truck right when i went through the window the truck was trying to eat him . his switches worked great killed the truck not him.    AND HIS TRUCK WAS IN PARK
==wgm
thanks again donny.   i will not  have a  truck with out a  kill switch in it.
smart button  ;D   good one  lonie
Proud and Powerful
got one on the steering wheel ++peace
