Mow Money MowerSports "A Cut Above The Rest"
Started by Boggerram87, October 15, 2009, 04:23:36 PM
Boggerram87
Almost Done With The Rear Suspension!
Newbie
Boggerram87
Should Be Mobile Tonight! New Rear Suspension Will Be Done!
Newbie
Boggen Joe
Gearz
Boggerram87
Gotta Be To Work In A Few Hours....Will Put Pics Up On Break
Boggerram87
 GotMud? New Lift And New Plate For The Dually
When u doin the front??  And what if u turned around yer flip brackets and run em backwards?  I bet yer shackle angle wouldn't be so bad, not that u asked for my opinion or anything lmao loll
Boggerram87
No I Know What Your Saying, I Deffinatly Have To Fix That Angle, Gonna Start Doin The Front After The Topkick Is Gone
Boggerram87
Welp Got The TopKick Gone (Thanks Big-Al) And The Front All Tore Down And The New Springs Mocked Up......Gonna Be A Lil Bigger Then Expected....Looks Like I'm Gonna Need A Lil More Rear Lift  ++peace But Like They Say....Bigger Is Better  ;D a=f loll
Rosco
muddnoob
Boggerram87
Redid The Mock Up On The Front And Its Gonna Be Bigger Then In The Pic....Got It Sittin Level Right Now With Tractors On The Back And The Center Of The Fron Axle Is 14" Off The Ground! Gonna Take Alot More Work And Be Alot Bigger Then Expected! Gonna Have To Rebuild The Cradle To Lower The T-Case To Have A Lil Driveshaft Angles, Rebild Link Bars...The Works.....As Much As I Hate To Do It I'm Probably Gonna Just Make The Blocks Bigger On The Back And Hope For The Best..And I'm Gonna Move The Rear Hanger On The Rear Back To Fix That Nasty Shackle Angle And It Should Lift It A Lil More
Boggerram87
Did Some Measuring And I Could Run Up To A 66" Tire Without Hittin...Though I Dont Think The Axles Would Like It To Much loll
Newbie
