fire extinguisher
Started by woody11769, November 09, 2009, 04:45:39 AM
do you have a fire extinguisher in you truck
yes
21 (75%)
no
1 (3.6%)
i need to go buy one
6 (21.4%)
Total Members Voted: 26
Merc09
I need to get a couple id like one in my dd and one in my bogger.
it may help save someones life someday...
just keep one in your DD somewhere
Going to buy 2 this weekend my truck caught on fire last weekend at Perkins and water barely put it out
Air Force Fireman
If you can, get a dry chemical extinguisher. It's a good one for engine fires. Otherwise make sure your extinguisher is ABC rated. I keep 2 in my truck. A dry chem as well as an ABC.  a=f
God Bless America!  a=f a=f
I have one in the console of my mud truck. if you run comp. boggs tech makes you have one. I have used them a play boggs on other people rigs.
Merc09
Got one in blood thirsty now!
chevyjake
Where's a good place to mount one. is there a certain spot that's a normal?
BUDGET BOGGER$
Merc09
Quote from: chevyjake on January 04, 2014, 05:42:32 PM
I mounted mine right in between the 2 front seats. where the center console would be.
Air Force Fireman
Where ever you mount them, make sure you have quick access to it. If a fire starts, you don't want to have to go to the back, open a hatch, move all the junk and then get to the extinguisher. Mine is right inside  the drivers door on the floor next to my seat. The big extinguisher is behind my seat. Either way I have quick access. Hope it helps!  a=f
