Project: Rat Phucker
Started by 4x4fun, January 31, 2010, 10:59:35 PM
jimmy101
Picking up the new engine on Friday  ;D ;D
New motor rips pretty good!
Had a set back on Sunday flipped the truck over in the field pretty much destroyed the cab and front clip as well as bent the frame but the roll cage did it's job and we didn't get killed soo metal can be fixed probably going too take it too my buds farm they have steel rails in the shop floor and a backhoe and skytrack too try and pull it back into shape add more metal too cage and go from there
jimmy101
glad to see you were not hurt.
Had the day off from work so I put the bumper up too the tree in my back yard and hooked a chain too the roll cage and with the help of a 2 ton chain fall got it back where it started  going too cut the top off the cab and add more tubing and gussets then put a different lid on it from a rusted out cab we got back in the woods might have too rename it Frankenstein
larry60
Full pass, sounds great too  applaudd applaudd applaudd ;D GotMud?
Hell yea, that 283 went right up stairs
Project Rat f%$$#r 2.0 has began
edmalead
