my 84 chevy long bed
Started by Eroq, February 02, 2010, 02:38:44 AM
duel1985
Your crazy if you slam it. Everybody and there brother now take sweet older trucks and chop the top and slam them to the ground. That truck looks bad ass the way it sits now. you never see cool hot rodded trucks anymore stock height! if it was me id keep it standing just like that!..........just like the bad ass it is!
probably not gonna lower it at all. rides way too nice!  plus i'd still like to throw some load range E's on the back and haul away
BIG UGLY
You still can haul with a Lowered truck.  You just need to do it the Right way and Lowering Shackles or spring under is the way to go with out losing hauling abilities.
It needs to be dropped 2 up front and 3 in the back, but then you will have to either trim the the rear wheel wells or tub it a few inches along with some deep off set rims.
No progress in a while!   Got a 4.10 Posi for the rear  from Big al     need to change pinion support bearings, cant find one in stock, gotta order it (there goes $40)
too cold to lay the rest of the primer down
==shrug The way money is i may have to end up sellin er!
BIG UGLY
Well   Thanks to redneck renegade i got me a little woodstove now. got it all fired up and did some work on in the other day.  Rear end is back togather, started doin a little more body work, fixin a few lil dings and dents.   Gotta pull er out and spin it around to do the other side, darn small garage! loll
Got a motor on its way, stock small block but atleast it dont pour antifreeze out the exhaust!
hmmmm no other real updates  ==shrug
Quote from: Flat_Black on January 27, 2011, 07:28:02 PM
slacker
hey now! cant do no painting in the winter with a chilly garage with no insulation!    Prolly spend most of the day tomorrow gettin the motor ready to come out and the last of the body work done, maybe even TRY to spray some primer.. paint says its good down to 40* so if i can get it that warm i should be set!
redneck renegade
i split hickory up real small it gets hot fast in my uninsulated garage
burn some locust its some tough stuff to split but burns hot
Blue
haydenlloyd88
damn it looks tough with those fats on the back, keep us posted!
More primer laid down yesterday, still a bit more to do, well quite a bit more!     Movin it around the driveway yesterday and i think im definately gonna need some Trac bars or maybe even a quick 4link kit for the rear.  talk about some wheel hop in the snow!  sucker dont like to go anywhere even with a posi
Thinkin onea these.. and keep the leaf springs for now...   ??? ??? ??? ??? ??? ??? ??? ??? ??? ???
http://www.summitracing.com/parts/CEE-2028/?sms_ss=facebook&at_xt=4d554d5fad9b8e68%2C0
But a healthy motor is more important!
eroq you get any more work done on this?? i wanna ride haha
Well, shes sittin down at Cannaerts now in fenton... Moving outta this place at the end of the month.. so hopefully without $600/month in rent i'll be able to get it done in no time.
Waiting on warmer weather anyhow to paint it...  Need a motor (got one lined up), pinion support bearing for the rear end, brake calipers and rotors, and 2 rubber hoses. 2 natural rubber tire tubes for them fat meats in the back... and that'll be it!   Might as well rebuild the tranny while i got the motor out.. that'll only be $100 and 4 hours of work
Hoping to get burnin some rubber soon!
Darkman
Cool truck. I like the old Hot Rod Chevy trucks.
