Picture question...
Started by unleashed, April 06, 2010, 10:43:52 PM
unleashed
First of all~my internet is dial up and it SUCKS! My question is...I was trying to look at pictures from the Gladwin bog in the pictures section. Some of the threads that had lots of pictures, I can see one or two, the rest are just outlined squares with a red X in the top left corner. Is that because of my internet, or is there a setting or something I need to change. The threads that had a link to photobucket were good. I can see all the pictures at the photo bucket sites. I just don't know if this is something I can fix or if it's just because of crappy internet connections. Any one?
try rite clicking to show image? prolly your dial up is the problem
do they still charge for dial up?
unleashed
#4
Thanks Big Daddy~I'll give it a try.
To answer your question this behavior can occur if one of the following conditions is true:
* The Web page includes an image type that is not supported by Internet Explorer.
    * The Show Pictures check box is not selected on the Advanced tab of the Internet Options dialog box in Internet Explorer, or the Toggle Images.exe Web accessory was used to disable images in Internet Explorer.
    * The image is displayed based on a script, an ActiveX control, a cookie, a Java program, or HTTP referral information, and your computer or network is configured to block one or more of these features. For example, you may have Internet Explorer or Symantec Corporation Norton Internet Security (NIS) or Norton Personal Firewall (NPF) 2002 configured to block one or more of these features.
    * Internet Explorer cannot determine the character set (also known as the code page or encoding) that is used by the Web page, or a file or registry key that is required to display the Web page that has the appropriate character set may be missing or damaged. By default, Internet Explorer uses the character set that is specified in the HTTP content type that is returned by the server, the character set that is specified by the meta element in the Web page document, or your Encoding preference if no HTTP content type is returned by the server and no meta element is specified in the Web page document.
