GMC AXLES and wheel question?
Started by cnoswalt78, November 15, 2010, 06:33:16 PM
PlumCrazy
cnoswalt78
it would be nice to make them, alot cheaper(if i could keep them round)
whats the worst that could happen ???  the guys getting 250 a wheel arent any different than any body else the first time they did it they were probbly unshure also         once ya do the first one it will be easy   the riveted together wheels would be alot easier to take apart also
cnoswalt78
have you had any problems riping tubes, i was told thats the problem with running truck style lock ring wheels, and they recomend car style
page69
did not rip tube had a 2 tube pop at the seem were the valve stem stuck through cause the liner was old . we replaced the liner with a new one and never had a problem since.
cnoswalt78
can you tell if it rips a tube? and have you thought about bead locks
page69
it will just go flat if the tube rips never had a problem with ripin a tube.as far as bead locks never realy thought of it but i could do that thanks
does chevy/gmc have a high pinion axle??
cnoswalt78
ok bein this bein our GMC & wheel and axle thing we got going on
im thinking how much (width) is to much on wheels?
this hasent been discussed before (i think)
Have you run wide wheels and had problem with big tires bead seats? OR?
