New winter project
Started by 3+3, January 11, 2011, 01:09:28 AM
ice87
You do know you can twin stick the 205 so you can run it in 2wd or front wheel drive. You can do it pretty cheap too
chico
Quote from: BUDGETBOGGER03 on November 25, 2011, 06:23:38 PM
will it be street legal?
Not sure, Depends on the state rules and regulations, I'll have to look into it. If I just need the basics It should be no problem. But , If they want blinkers, Wipers, bumpers, ect. I don't know if I'll do it.
TOMAC
if u ever want to sell some paddles i will always have cash for you lol
355REDNECK
what is the specs like wheel base and what kind of frame
WHEN IN DOUBT THROTTLE OUT
Quote from: 3+3 on November 24, 2011, 03:36:03 AM
Quote from: ice87 on November 24, 2011, 01:06:12 AM
How do you plan on getting you driveshaft rotation right?  What wheelbase is it?
Using Toyota Axles, The pigs can be flipped to the top and that reverses the rotation. The only negative about using the np205 t-case is that, when its in 2wd, it will be front wheel drive. The rear output on the t-case drives the front wheels and the front output drives the rear wheels. shouldn't matter too much, it's built to be 4x4.
twin stick the 205,  nice project Stan.
i think you just need to fallow what dune buggy needs to be street legal its kinda the same thing
Quote from: 3+3 on November 26, 2011, 04:53:55 PM
it is really easy to pass inspection have built buggys and had them registered
As others have said... twin stick the 205 to solve the fad problem.
Always wanted to do something like this.  Looking very good.
RBSracing
REDNECK bull p00 RACING!
3+3
Quote from: 355REDNECK on November 26, 2011, 06:14:29 PM
Frame started as a legends frame but has been hacked up pretty good, I'ts been widened, Lengthened, and chopped. I ended up just building a straight frame to work off and I have been building as I go. The wheel base is right about 9' 6" or 114" but may change if necessary.
Gearz
Great !  Project looks like fun.
Quote from: Orangecrush on November 26, 2011, 09:34:28 PM
or leave it in 4wd and unlock the front hubs ?????
Blackout
Dana 300. Lighter, lower gear, strong, and very easy to twin stick for full frt  and rear isolation. Plus less distance between out puts if centered pinion is desired. Cool build for sure.
muddnoob
danwheeler660
sweet build can't wait to see it when its done.
.1996 bronco 351 32.11.50 15
84silverado
ive looked into it because i was driving a vechile that was a one helluva beater lol. but all you need in michigan to drive on the road is front and rear bumbers, firewall, and tail lights. you can you arm and finger signs when turning lol
mudmaster
lets rip
Boggerram87
Even If Its A Lil Fella Its Gonna Be Sick When Its Done
