355 tbi
Started by OHEARN.2012, January 27, 2011, 09:34:58 PM
ill deff be playing with it. u saying flat tops are bad for playing??
Blue
Quote from: OHEARN.2012 on February 04, 2011, 03:54:12 AM
i wouldnt think so but not 100% sure
i want it to be idk how to say it but like halfway between high performance and stock  so yea suin like a mild build this will be in a dd will be daily driver/ weekend wheeler/ tow rig for little boat and snowmobile trailer. idk wat would you guuys think. lowend torque at low rpms or high rpms? or vice versa just want any or all your opinions. this is my FIRST engine build any info from you guys who have done this or make a living off of it help me out
go dished. theyll still give ya more CR than stock and u can just drop any kind of heads out there and not worry bout clearances of the valves. easier the better
on a budget build wat kind of heads would you prefer? would stock heas be enuf or no
Quote from: OHEARN.2012 on February 04, 2011, 06:52:15 PM
stock would be in ur price range for sure. just take them to a shop and have them do a valve job and make sure all the seats are still good
ok at the shop when they bore the block out do they usuallly completely clean it or no?? same with heads?
yea they usually do, kinda bad practice if they dont
#29
Quote from: camok10 on January 30, 2011, 04:12:34 AM
yes thats the intake i was talking about. roller rocker's have a needel bearring fulcrum were they bolt to the head's and they have a roller tip too were as roller tip are the same as factory but with the addition of a roller on the tip they came on factory 305h.o. and tpi motor's. as far as the 454 tbi unit as far as i know all that is required is to bore out the intake to accept the larger throttle bore's. disturban would be the one to ask he did it on his suburban. for piston's i would find one that would run roughly 9-1 comp witih your head's and if i rember right the tbi head's came in  either 5x or 64cc so i would identify  that befor i decided on pistons but i would go with hypereuctic they would be the best bet for such a mild build. and for cam's im partial to comp but crane and lunatti are also good.
I bored my stock intake out to accept the 2" butterfly's on the 454tbi because I work at a metal fabrication shop and have access to all the tools to do the job. If you dont have a way to bore a stock intake or an aftermarket intake (AS far as I know only 454 intakes have the 2" bore, even aftermarket sbc tbi intakes such as Edelbrock only have 1 15/16th bores and would need to be bored as well) an alternative would be to buy a 4brl manifold, a tbi adaptor and just bore the adaptor out to 2", you could probably do this with a die grinder.
You can get an adapter plate here http://www.tdperformance.com/products/?id=3225
Use a Edelbrock 2101 manifold http://www.jegs.com/i/Edelbrock/350/2101/10002/-1
It would be much easier to do it this way because there is a lot of meat to take out of a stock manifold, an aluminum TBI intake would be easier to hog out because it is aluminum but I think the easiest is to just hog out the TBI adapter and run it on a 4brl manifold.
For a solid 300hp 350 with a 454tbi you will need to use cop car injectors and a 255gph fuel pump, and an adjustable fuel pressure regulator to dial it in, you will need to have chip reprogrammed to dial it in as well.
I used a walbro 255GPH inline fuel pump as well as the stock pump in the tank, I just plumbed the fuel line coming out of stock pump into the 255gph pump and mounted that on the frame rail, this way you dont have to drop your tank!
Tuning it all was a Muther F***ER...I had my chip reburned about 15 times before getting it right, all reburns are free except shipping/handling charges.
A wideband O2 sensor will be your biggest help in tuning it because you will be able to see your A/F ratio at any given rpm.
I was running the cop car injectors at 18psi of fuel pressure and figure I was making a solid 300hp with cam and a little head work.
This is the cam I used
Summit Part Number: EDL-2102
Basic Operating RPM Range: Idle-5,500
Duration at 050 inch Lift: 204 int./214 exh.
Advertised Duration: 278 int./288 exh.
Valve Lift with Factory Rocker Arm Ratio: 0.420 int./0.442 exh. lift
Lobe Separation (degrees): 112
After doing head work and cam it had a lot of low end grunt but would nose over at about 4000 to 4500 rpm...the 454tbi fixed all that crap though and that thing would scream up to 5500rpm and it was chirping the tires on dry pavement shifting into 3rd on a 3 ton 1988 Suburban with a TH400 tranny. Surprised many people who thought they was going to jump me at a light and get in front of me ==roll
Might have been making a little more than 300hp?
Raced a few trucks, one was my friends newer chevy with a 5.3 and I took him off the line, 400ft down the road I was at least 4 truck lengths ahead but I could not gain any more distance nor could he catch me.
If running more than 300hp you want to run the 454 injectors, more than 400hp it is time to start looking at Carb power...Brian has the whole write up on what works and what dont at his site tbichips.com...I basically just used his site to guide me in the right direction.
Now I want to build the exact same motor and put it in a nice first gen S10 blazer or a 6.0 swap, I think I am leaning towards the TBI motor though because the swap will be so much easier.
PS: If I did it all over again I would upgrade to Vortec heads, only reason I used the stock heads is because I ran out of money but I took them to work and did a mild port job on them, decked them, cleaned them all up ect. The stock heads will actually give you more low end TQ as compared to Vortec heads but once you get into higher rpm's the Vortecs are the way to go!!!
PS: Again...after all was said and done I had to use premium fuel 92octane because the decked heads raised my compression and the chip I had burned had a lot of timing in it...truck got 10mpg on the hyw and 10mpg in the cty. Down hill 10mpg, up hill 10mpg, wind behind you 10mpg, head wind 10mpg, towing a trailer 10mpg.
It was a 3/4 ton Suburban though and it had a TH400 tranny so no overdrive, I think that really hurt gas mileage and 10mpg on 92 octane gets real expensive to drive but you know how far you can go just by looking at how many gallons you pump in it 40gallons 120 + dollars = 400 miles ==roll
Read this 10 times forwards and backwards ==roll http://www.tbichips.com/truckmods.htm
ABlockhd
I wish I had half that knowledge when i built my tbi motor
Quote from: ABlockhd on February 06, 2011, 12:03:11 AM
Another great place with a wealth of TBI knowledge is 3rdgen.org they are kinda funny there though and if you tell them you are building a truck they tend to stop answering your questions...tell them the motor is going in a 1989 camaro and they will bend over backwards to help you ==roll
Also as far as I know Brian is selling TBI chips that are programed to work with certain engine packages. He will tell you what cam, heads, injectors, fuel pressure, ect, will work with what chip he is selling on ebay...this will take a lot of guess work out of putting a package together that works right from the get go!
so you guys are saying stay with stock crank mild cam stock heads with valve job and 454 tbi unti will give me a decent motor?
Quote from: OHEARN.2012 on February 06, 2011, 02:49:15 AM
Just rebuild bottom end stock, use the same cam I did, vortec heads, 65 lb/hr cop car injectors, 16-18psi fuel pressure and email tbi chips and tell him what you got and get a chip, he has done so many of these friggin things now he probably has a file saved just for these mods...you will be good to go.
When you install new cam make sure you get new valve springs also, the old springs will not work and you will have major valve float!
ok is ur cam good? as for vortec heads arnt they pretty expensive?
Quote from: OHEARN.2012 on February 06, 2011, 05:28:05 AM
The cam I used was good till 5500rpm, pulled strong and idled nice and smooth, I could have went a little bigger but then you are sacrificing bottom end torque. You should be able to pick up some Vortec heads for a few hundred bucks...if you cant just freshen up the stock heads. The stock heads will give you more bottom end torque...when I built my motor my main concern was keeping the bottom end torque but increasing my upper rpm range from 4000rpm to 5500rpm and making more top end horse power...I achieved that goal.
That motor would pull a house, wind up to 5500rpm in the mud or freeway on ramp, had smooth idle, the wife could drive it every day, would start in the coldest weather first crank.
If you was to drive that truck around in the city you would think stock motor...when you jumped on the freeway and held your foot in it and it got above 5000rpm then you would scratch your head thinking WTF ==roll
personally im just looking for an engine with some power i gont want to be pushing 5000 plus rpms i mean this is just going to be my budget 355 build later on down the road a bbc may be in the works. but as of now i know engine in truck is going to need rebuild as it runs 10-20 oil press at idle but yea all im rely doing is daily driving this truck and weekend wheeling plus towing snowmobiles quads small fishing boat etc nothin big and i still wanna use reg pump gas
Quote from: OHEARN.2012 on February 06, 2011, 05:47:58 AM
Just do the same thing as my build except use the 4brl manifold and adapter. Freshen up your heads but dont deck them that will keep compression stock and used a stock bottom end, when you get your chip burned dont add as much timing as I did, you will probably have 275hp nice daily driver that will run on 87 octane. I just went for as much free horse power as I could by porting heads and decking them to bump compression ratio...it was not free when I had to fill up using 91 octane ==roll
When I build this motor for my s10 I am going to build the exact same motor I told you to build but I will be using the vortec heads but no decking to keep my stock compression ratio this time.
I figure with a S10 blazer being a lot lighter than my old Suburban plus having overdrive I should get between 15 and 20 on the hyw...that's kinda important to me right now because this will be my daily driver for the next few years and gas prices are going up.
Future truck in a few years is going to be a diesel running on homemade bio diesel and then I wont care how much gas cost ==roll
I want to either get a 98 or newer Suburban and do a duramax transplant or a used quigley 3/4ton chevy 4x4 conversion van and transplant a duramax in that...need to save for a few years though because that project will not be cheap!
Broncoholic
Did you tear it down yet? Every thing has to be baked, & Mag checked before anything can get started.
1* Check the bore if OK just hone & re-ring it, 3 angle valve job & TBI intake, throw a RV cam in it and good to go. Use King Bearings for better embedding of dirt  if your going in the mud & sand.  You might get lucky & just have to turn & polish the crank .010 - .010 Stock bottom end is fine to 500  HP. Might want to get ARP Waveloc  Rod Bolt kit.
http://www.google.com/url?sa=t&source=web&cd=2&ved=0CCEQFjAB&url=http%3A%2F%2Fwww.summitracing.com%2Fparts%2FARP-234-6301%2F&rct=j&q=arp%20waveloc&ei=nulOTd3IKonKgQfxhKFA&usg=AFQjCNGTkG_Uudwk-HQ5iC74RNq_TjSwyw&cad=rja
2* Take it .030 over & get Flattops so at a later date you can add better heads, RV cam will still give you some good low end for towing & around town, Keep what you have to keep Cost $$$ to a min. Save up for better heads next year. I budget allows get some Forged Pistons for the long run.
Tell the cam Guy it is going in a Class A RV = Good to go. .430 - .460 Max.  Lunati is Good The Voodoo series cams Nice Lope. EFI Compatibility = Howards & Edelbrock are also good cams.  I do not like the Comp Imports anymore.
Roller rockers are nice if you can afford them lot of work to make them fit.
Just a matter of $$$ Need ARP Studs & New pushrods.
You could have $1200 to $23oo into it just depends on what you find.
wondered does the block i use for this engine have to be suin that was tbi?? or could it be suin off a carbed motor?
