need help with th350 trans
Started by Thumper, March 23, 2011, 11:54:58 PM
Thumper
after couple days of sitting my trans won't engage unless I rev up the motor. It is in my bogger. was rebuilt before last yrs. start of bog season, worked great behind my 406 but when that blew up I replaced motor with new 355 and since putting it in it has done this. It works all day after first reving engine before loading to go to bog, cannot understand why or how to fix, any ideas. The converter was new and I changed the fluid and filter.
THE D&D CREW
did you hook the trans cable to the throttle and adjust it right?
Thumper
there is no trans cable, other than shifting cable. it worked fine before I put new motor in
THE D&D CREW
im goin to bet that you made sure the converter was fully seated? does it have enuff fluid?
buddman (AKA Mick)
I had a 700r4 that was the same way in my sons truck, never did find out what causedit we  ended up changing it, let us know if you figyre it out, just courious.
A rednecks famous last words..........HOLD MY BEER AND WATCH THIS!!!!!!
86 Blazer on 38's, 355
Shouldntt there be a cable from the carb/tbi down to the side of the trans by the governor.. idk autos all that much ==djdj
mudboggincrazy
Quote from: lilred on March 24, 2011, 06:19:55 PM
not on a 350 turbo
MR NASTY
ddmachine
th 350 do have a kick down cable some trans kits eleminate them i would look into the pump aera i had one do this put a new pump housing on and was fine
Thumper
thanks for all the advice guys, I am getting ready to change body and pulling trans, taking it back to builder and see what's up, he seems to think the pump is weak or a seal somewhere cracked. will post results when i know again thanks
THE D&D CREW
cnoswalt78
thats what it sounds like (the only reason i know is becouse of explorers) the 2 I had did that usally from converter not being seated all the way,(that is what the tranny shop said)
Yeah deriks right, hes thinking of the kick down cable. that wouldn't cause this when trying to move in 1rst though. Im betting the tq convert didnt set right or its not primming properly.
Quote from: ddmachine on March 26, 2011, 03:24:09 PM
Oh sorry didnt see this post already.
