project nextime
Started by roodawakening, March 27, 2011, 05:29:40 AM
roodawakening
thanks travis should run pertty good and yes it is nice to have a pit next to the shop to test and tune
thebig10
git r done john i will come help you this week .let me know
coming soon big blown 10....
roodawakening
well come on down sunday be working on it all day sunday hears some more pic
355REDNECK
did u buy chris headers to
WHEN IN DOUBT THROTTLE OUT
roodawakening
yes i did the ones in the pic are not the one i got from chris
355REDNECK
how far do u have to go before its done
roodawakening
i got a lot of litte stuf  wire the truck gas pedel brack  pedel  fule cell and plum the injection
roodawakening
got some more work done on the truck stearing clom in seats in place ready for mounting fire wall all bolted up in place getting closer
roodawakening
hope to get more work on the truck wensday hope to get the bracks done
Axlejack
sweet machine!!!!! for sure. I bet its really gonna rip. Thanks for sharing I got a few ideas for my truck from you.
Boggerram87
roodawakening
The goal of the 9 second breakout event is to come as close to 9 seconds without coming in under 9 seconds. Any times less than 9 seconds such as 8.998 will be disqualified for that run. We have live action timer scoreboards located at the end of each pit that can be seen by the driver easily during the run. This can be an aid for the driver to cut a close time. All street type, stock or hot street, and 4 and 6 cylinder trucks can run in the 200? pit. All of the modified, super modified, and unlimited trucks will run in the 250? pit. The pits will only have a maximum of 24 inches of mud in them. Since these are events and not races, the pits will be made hill and hole style and not hill and hole standard. The reasoning for the pit adjustments is to allow almost everyone to come out of the pits in the time allotted. The only pit grooming will take place half way through the event, after the first round of each pit. Each driver/truck combination entered will have 2 passes. It is the better of these two passes that will be scored.  A driver can place more than once if in a different truck, and the same truck with different drivers can place more than once.
Must have brakes and reverse
All gutted trucks/trars/cars must have roll bars
All drivers will have seatbelts or harnesses
All drivers will wear helmet Dot/SFI rated
All vehicles will have a fire extinguisher in reach of the driver while belted in Any Type of tire Allowed (Dot, Cuts, Paddles, Agri, Monster truck, if it will fit in the pit you can run it)
Any type of engine Allowed (Automotive, Aircraft, Rocket, Briggs and Stratton) all exhaust must be directed away from spectators and officials. Rocket and aircraft engines must be directed straight up.
Any type of Running gear as long as it is 4 wheel drive only (No 6x6 or 8x8 allowed) ½ ton, ¾ ton, 1 ton, 2.5 ton 5 ton 10 ton all are Okay
All Alcohol, Nitrous, Blower, Nitro methane, vehicles must wear fire suit rated for your fuel minimum, highly recommended for all drivers.
Absolutely no drinking of any alcohol or mind altering drugs,( legal or not), before driving. Any and All violators will be ejected with No Refund of any kind
trailman
Dr.Feelgood
Quote from: roodawakening on April 14, 2011, 01:11:40 AM
The goal of the 9 second breakout event is to come as close to 9 seconds without coming in under 9 seconds. Any times less than 9 seconds such as 8.998 will be disqualified for that run. We have live action timer scoreboards located at the end of each pit that can be seen by the driver easily during the run. This can be an aid for the driver to cut a close time. All street type, stock or hot street, and 4 and 6 cylinder trucks can run in the 200’ pit. All of the modified, super modified, and unlimited trucks will run in the 250’ pit. The pits will only have a maximum of 24 inches of mud in them. Since these are events and not races, the pits will be made hill and hole style and not hill and hole standard. The reasoning for the pit adjustments is to allow almost everyone to come out of the pits in the time allotted. The only pit grooming will take place half way through the event, after the first round of each pit. Each driver/truck combination entered will have 2 passes. It is the better of these two passes that will be scored.  A driver can place more than once if in a different truck, and the same truck with different drivers can place more than once.
Is this from Darral Jones place in N.C.
89 YJ with BBC, 60s,&44s
roodawakening
yes i think rule will make the playing feild for the trucks with les hp be able to compete with the trucks alot of hp and make the driver learn his truck beter
thebig10
i agree they all should use these rules for the comp boggs it  makes it fair  and there is only one class .
i would like to see this happen ...
poorboyzmuddin
IT IS WHAT IT IS.......
355REDNECK
it might happen over to orleans. i will ask chris if he will do it
roodawakening
not alot done on it in the last week but did get tre rear ster hook up  and plumb and working  lot more to do if i could get some help  down at the shop hint hint big 10  could get it all done by next weekend
gwilliams
i can help let me know man
84 short box chevy 14 bolt rear 44 front detroit lockers
2001 ford f250 8'' lift 37'' tires
