gear ratio in a dana 60
Started by danwheeler660, April 11, 2011, 03:44:00 PM
danwheeler660
i have dana 60s front and rear with 38 15.50 16 tires.I went out and jacked the truck up and for 1 complete spin of the tire my drive shaft only went around 2 1/8 turns.So what gear do you think i have.the truck is at 2500 rpms doing 65 on the high way with a 302 punched 30 over...any help would be great thanks...
.1996 bronco 351 32.11.50 15
4.10s or 4.56s
http://www.4lo.com/calc/gearratio.htm
i put in everything you said, but for the tires i put 37.5, cuz most of the time they arent truly what the size wall says, plus wheel width, etc. input more precise numbers and there ya go
danwheeler660
Pull the covers, count the teeth and divide. Its the ONLY way to be sure.
danwheeler660
but i don"t know how to divide...LOL
Quote from: old school truck dude on April 11, 2011, 05:00:14 PM
ed_ley1980
I have a dana 44 and 9 inch with 4:10 gears if u wanna swap then u will know the gear ratio for sure lol
danwheeler660
nope i will keep my dana 60s i just going to get a big block and stick it in there to get the tires moving easier
Quote from: ed_ley1980 on April 12, 2011, 01:19:43 AM
Yeah a big block would help that beast roll a bit better
4x4xdodgeman
dose it have a pois in it? if it dose not you need to spin the tire two times around,
danwheeler660
Just pull a cover and b done with it.  Only real way to tell like old school said above.  Count ring teeth and pinion teeth and divide
danwheeler660
what do i divide by how do i do it?
if you take the ring gears number of teeth, and divide them by the number of teeth on the pinion gear, that will give you the ratio of your axle
Yep!
Quote from: Le Dude on April 12, 2011, 01:54:19 PM
Dollar store has calculators  ;D
danwheeler660
looks like i have 456 gears.What size would you suggest i put in them to get more power.Like i said it is very slow when you punch it.I want more low end power.It is awsome in the mud and rocks in low range.But i need more power for the sand so i need to regear it intill i gat a new motor for it.Im looking for a 460 or 351 to rebuild.
something is wrong if your having trouble with 4.56s and 38s. i have a mild built 360 turning 38s with little effort and i only got 4.10s
Yeah...but he's basically got a one ton crew cab with a cap...that has a 302..........that's why its doggin out in 2hi
Step up the horsepower a little  ;D
