2 1/2 axle???
Started by redneck ohearn, April 28, 2011, 02:47:32 AM
redneck ohearn
cnoswalt78
i dont think there gmc 's pm frank and ask what gears he has.
damn_ford
IF there gms the front will be reverse rotation. either need to run the gm t case, flip the pig, or flip the whole axle. as far as i know gm 2.5s only came with
6.17 or 6.38 gears though
page69
if they are the 1 1/2 ton they damn near look they same they have 6.72. they are the same as the old gmc trucks.my brother in law has them axles under his truck they are a little narrower than the gmc's. the spider gears go out on them easy that mite be what is the problem. then u can just weld it up.they look like over sized ford 9 inch axleswith big skinny drums if they are wide drums they are 2 1/2 tons and have 6.17 gears. if they are 2 1/2 tons let me know i have all kinds of brand new brake parts baking plates brake shoes springs wheel cylinders or i got patternsfor disc brake conversion front and rear.
redneck ohearn
ok ill let you guy know im gunna go look at them saterday
Quote from: homewrecker john on April 28, 2011, 03:53:30 AM
i couldnt tell you on if they would bolt up or not...never ran them....Le Dude had or has a set right now i think....pm him...he should be able to tell you.
i had top loaders ;)
cnoswalt78
Id bet there wide 5 lug m715 axles, or somthing od like that, what ever they are dont get them go dana 60 or 2.5 ton and dana 60 would be better.
redneck ohearn
Quote from: cnoswalt78 on April 28, 2011, 03:00:06 PM
there 6 lug but thats what i was thinking i dont really need them i got d60 and 14 bolt, they were cheap and the the guy said they were rocks
