kick down cable cobble...
Started by scooterbob, May 07, 2011, 01:27:06 AM
scooterbob
well finally got the lift done on the truck  got motor in running strong
not really sue on how to hook up tranny kickdown...got it on a bracket (with zip tie cause tab broke)
when hooked up i pulled it till tension was on but hits second really hard..
is there a correct way to adjust it in?
thanks
you want it all the way out at full throttle.
yeah bubba, if it's hitting second that hard you got it to tight which puts to much line pressure through the clutch packs for what ya need, but with that tranny, it's better to have to much than not enough, i'll check it out, might have to put the other cable on
scooterbob
when i put it on i just brought tight and hooked with out it bein wide open..thanks
scooterbob
still aint right goin get another cable and start over
