School me on gear ratios
Started by OHEARN.2012, June 13, 2011, 06:52:13 AM
85cHeavyMetalBogger
Id say if its a straight bogger, go 5.13s, I run 39.5 and 4.10s with a 208 and about 400hp......it does good, but I would be happier with taller gears.  I'm going 5.38s when I do mine.......but I'm gonna go to 44s prob
str8 up bogger nuin else maybe pull some trees out lmao
Quote from: Blazin40s on June 13, 2011, 08:27:19 PM
Boggers will snap those shafts.....may wanna trade someone with tsls 2 of yer tires and run tsl up front and bogger in rear
I ran 44 bogs on the jeep with a 10 bolt open diff and never had a problem... 5:38 gears with 600hp +
If you plan on running 40 with a 208 you should go with 5:13's....your tranny has more than one forward gear right? Plus if you go with a 5:13's you could run a bigger tires later without changing gears again.
If you change the gears before you change the case you could run 35s...if you change the gears and case you will NOT have a lot of tire speed.....
would i be better off with a 205?
203 and 205 have the same gear ratio which is 1.96:1 and the 208 is 2.73:1
205 are tuff but harder to find
208 is 1/4 the weight, plentiful, and has a much better gearing....
I think your best setup for your truck is as follows
35" tires, 5:13s with 203 ( since you have mentioned that funds are tight
40" 5:13's and 208 ( wont need high hp to run this setup and then you could run bigger tires up to 44"
All this is IMO...that is what i would do if i was in your shoes....
Here is a link with 44 bogs, 208 and 5:38s and stock motor ;) !
85cHeavyMetalBogger
hmm john im liking that setup im building it over this winter so i just have to budget for it
85cHeavyMetalBogger
got captain crunch/crunch berries?jk.. i dnt knw that i need anything, got any guns? 100 buks takes it, well worth it.
Quote from: OHEARN.2012 on July 28, 2011, 02:19:29 AM
Quote from: 85cHeavyMetalBogger on July 27, 2011, 10:09:25 PM
Quote from: OHEARN.2012 on July 27, 2011, 09:20:42 PM
Quote from: 85cHeavyMetalBogger on July 27, 2011, 08:36:38 PM
yes sir
looking for any trades?
i dnt knw, what u got
i got some canned goods and cereal lmao watcha need
u dont know how bad i want it man that is a steal and i need one with brakes and urs has brakes
85cHeavyMetalBogger
new brakes, calipers, warn lockouts.. calipers shaved if ur runnin 15 in rims
85cHeavyMetalBogger
u rely shud save it for me man id buy it here in a month or 2
85cHeavyMetalBogger
cant pass on a sell if you dnt end up getn it u knw
we may missing a key question here; what is best tire speed or torque?
Quote from: 390JOE on July 29, 2011, 08:51:26 AM
wheel speed is king!!! keep them tires clean!! the faster the wheels spin the faster you go!!!
MuddIce
thanks for the lesson... lots of good info here.. I am getting ready to change out my 1/2 ton to 3/4 ton and was just ondering what gear ratios to go with.. Thanks
MudIce
BackYard Mudders!
MudIce
BackYard Mudders!
79 Ford Bronco
