MY 98 1 TON S10
Started by D60KING, July 04, 2011, 03:04:13 PM
great to see you there eric! let me know if you need a hand on it!
 Got something worked out still have to do !!
355REDNECK
WHEN IN DOUBT THROTTLE OUT
middleroadBOB
looking good! sounds awesome!
Well, I got the air intake done, hope not to have to deal with water no more ? Played with the carb a little, made some adjustments to that, sealed up the Engine Box, Redone some of the wiring to spread out some of the amps on the switch panel & added some more relay's, & hope that takes care of the wire over loading problem ? & Had to fix's my grill after one run it got broke. hope to have good time at the Iron Wheel Bog !!
looks sweet!!!!!!!!!!!  ill see you there!!!!
BoggerBro
See ya Saturday Eric, don't forget your squeegee like you did at Town road!
that should really help with the water I did something similar and havn't had any issues with it.
Quote from: BoggerBro on May 11, 2012, 01:55:34 PM
I have "two" already in the truck.
do you have a easy access panel to your motor on your boxed in front end? I got some hinges and pins for my hulk truck after almost burning my brand new motor up due too a few electrical misshaps lol
Quote from: Bryank on May 11, 2012, 08:15:51 PM
The Box is made of (4) panels that lock together with studs & pins, The top comes right off & the front panel hold it all together with two bolts, come apart very easy & fast. took me some time to get just right to all work together, but turned out nice. ( I think )
Just curious but is the motor completely boxed in, if so doesn't that keep the heat in and won't that keep the engine hot with no way for the heat to get out, even with two radiators? Just wondering keep up the good work it has came a long way sence u started
Quote from: erikmud on May 12, 2012, 12:12:25 AM
not if your cooling system works right... mine was set up kinda like that and I had no issues!
The back side of the motor is open, The headers run out the bottom & I have them heat rapped, But I really don't know yet ?  I have only had it out once so far ? & had other problems with some of the wiring that made it get hot, I plan on getting the header coated to help with the heat in the box, so still trying to work things out, I did think about that but had to keep the water away from it. I'll find out soon ?
swampfoxjr
having the headers coated will make a huge difference. i sent a pair of my buddies to jet-hot and had them coated. he can drive for 30 min to my house open the hood and 10 min later hold the header. its crazy
C:\Documents and Settings\All Users\Documents\My Pictures\Kodak Pictures\red dodge\100_0848.JPG
Quote from: swampfoxjr on May 14, 2012, 12:36:43 PM
Yea, I know I had the Headers for my car dun at Jet Hot in the (black) Inside & outside & yes In no time at all you can touch them NO problem !! Except the cost for it & the oversize shipping cost ! But Yes that is the plan.
Hey Eric could you get me some pics of how you got your coolant lines run and the inlet on the motor and radiators
Quote from: OHEARN.2012 on May 22, 2012, 02:37:15 AM
Yea, I'll get some tonight. This is how it is hoked up,
Quote from: D60KING on May 22, 2012, 04:26:11 PM
thanks
