HP desktop Monitor wont turn on
Started by RIP_K52007, July 23, 2011, 10:31:54 PM
G/f brought her desktop over, its a HP with windows vista ( ==censor) anyways... turns on and everything, but it wont trigger the monitor to come on. any idea? she said it worked fine last year when she unhooked it all.
Crazymays77
Did u check to see if it's not the monitor that is bad
yea i tried the one from my desktop that works fine and it still dont turn on. and yes its plugged in. ==roll
Bad monitor.  Mine did the same thing last year.
Quote from: Blazin40s on July 23, 2011, 10:46:38 PM
Quote from: lilred on July 23, 2011, 10:40:43 PM
So does the other moniter work on it???? Or am I misunderstanding?  loll
Quote from: Blazin40s on July 26, 2011, 04:41:00 PM
Did u check the video card?
nope no monitors work on it... and how to you check the video card? yes its there....  lolol do i gotta sniff test it?
Quote from: Blazin40s on July 26, 2011, 04:40:41 PM
slightly lol... i was saying the monitor works fine on my other desktop, but when i plug it into hers it dont turn on.
Crazymays77
So there is something wrong with her computer.  More than likely it's the video card.
shmooe
Didn't read the other post but most the time the ribbion cable goes bad. Very hard to replace if you haven't done it a lot. Cables cheap if youcan find one.
Swap yer video card in there and see if it works
Quote from: Blazin40s on July 27, 2011, 12:18:59 AM
think that will work? mines a frankenstien gateway/random parts and ducktape based off a 97' tower and mother board...
hers is like a 09' HP
I dont want to fry something loll
Quote from: betterbeaters on July 26, 2011, 05:22:24 PM
scrap it! lol
- that's usually his answer too!  ==roll
Like everyone else said, video card, however i bet the video card on that HP is hard wired into the motherboard, not an actual card. If this is the case, buy a cheap card that will plug into whichever slot you have (pci, isa, etc.) and bingo, you are all set.
dsJeep
in less your GF  spent a good chunk of change in the computer its an onboard video card, you'll have to find out if it can take a AGP or PCIx-16, if not you'll have to find a PCI card...
if you can post the model number I can find a card that will work just fine for it...
went n dug threw my parts box.. only video card i have wont work... so i know its not this kind whatever it is loll
dsJeep
#18
that looks like an AGP 4x card, and being as she has a slim line that card wouldn't have worked, you'll need a half height card...
this is what you need, and it should work out just fine, then upgrade the RAM and ditch Vista...
http://www.newegg.com/Product/Product.aspx?Item=N82E16814133316
i wish i could ditch vista but i used my only good windows 7 disk on the grandparents computer. ==doh
Ill see what i can do about getting the video card
dsJeep
it would, but the other one costs less...
your money though, and we all know how loaded you are :P
Quote from: dsJeep on August 17, 2011, 07:42:39 PM
lolol yea right... I just need the tv hookup on that card cause thats what we are going to be hooking it to now.
dsJeep
you can hook the one I listed up to a TV, its set up for DVI HD...
Quote from: dsJeep on August 24, 2011, 10:46:51 AM
english? lol
dsJeep
if you have a TV with either HDMI or DVI you can use that card I showed you, most TVs sold the last 4 years have one of the two...
you'll just need an adapter to hook up to HDMI if its not already included with the card...
Quote from: dsJeep on August 24, 2011, 09:48:58 PM
I have a adapter that goes from VGA to RCA (yellow white and red) ??? that work?
dsJeep
if RCA is the only way you can hook it up to the TV, what kind of TV is it? maybe post a picture of the various connectors in the back or side and I can tell you how it needs to be hooked up...
Quote from: dsJeep on August 25, 2011, 10:57:08 AM
the tv has hdmi and s video... but the only adapter i have without going and buying another one is VGA to RCA. (which i havent got to work since i bought it)
dsJeep
ah, you can get a DVI to HDMI cable cheap from Meijers or Wal-Mart, neither card comes with cables anyway...
the card you posted has VGA and S-Video, personally I think the resolution from DVI/HDMI is better, but either card will work...
