377 sbc
Started by ballistics-10, November 03, 2011, 04:48:36 AM
ballistics-10
377 SBC is a 400 block with a 350 crank... but is it 5.7 rods or 6 inch rods?
I believe it depends on type of piston your useing ???
woody11769
is that conciderd destroking a motor
Jr
you can use wither a 5.7 or a 6.0 rod.... depends on the height of the wrist pin location on the piston your using..
Jr
but if your de-stroking a engine... build a 352.....  they are nasty engines... you just use a 237 crank not a 350 crank
more rpm's
ballistics-10
so you can buy a piston for a 6 inch rod and run it with no problems and the same with a 5.7 rod?
bigmud44
if you know any roundy rounders talk to them 377 was the engine to have in that sport for long time ;D
Quote from: bigmike on November 03, 2011, 02:28:04 PM
yes you can even use a 6.125 rod I think
scooterbob
unlce uses 283 crank on those...rods have no idea
there's really only 4 sbc cranks.. the 3 inch stroke 283 and 302 crank, the 3.25 inch stroke 307 and 327 crank the 3.48 inch stroke 262, 305 and 350 crank and the 3.75 inch 400 crank, the shorter the stroke the higher the rpms you can run withgiven parts, for sbc the best length rod you can use is teh 5.7 inch, especially with longer strokes, if you use the shorter 3 or 3.25 inch strokes than 6 inch rods would be alright too, but don't use the longer rods with the longer strokes, and the rod length is also crutical to your piston selection, they are designed to be used with a given rod length. also i would reccomend using full floating wrist pins if you want high rpm's,
ballistics-10
so you are saying not to use a 6 inch rod with a 400 block and a 350 crank?
85cHeavyMetalBogger
if u do u need the right piston so u dnt hit head
with the 350 crank you can get away with it, but it doesn't leave a whole lot of room for the oil rings, and with the 400 crank it's a very bad idea because their on top of one another
ballistics-10
#14
what? so the 350 crank and 6 inch rod is no good to use? so a 5.7 rod would be better?
yeah with a 350 crank the 5.7 is a better idea
ballistics-10
That. .3 of a difference makes that much of a difference? Anything to watch out for?
that .3 inside a motor is a lot.. that's 300 thousandths , and that's that much more piston between your wrist pin and oil ring pack to think about that way... and a big thing to be carefull about is not to get carried away with your build, just because you spend top dollar on a bunch of parts doesn't mean their gonna work together...and watch your compression for iron heads and pump gas keep it around 9 to 1 and for aluminum heads keep it around 10 to one,, other wise your gonna have issues with pump gas... and there's a few different ways to get your compression up or down, i'd be glad to give ya some help or pointers during your build. there's a few guys on here that are running motors i built and their happy with them.
Boggen Joe
I'm running a 400 crank(3.75) with 6" rods with no prob, rev to 7000 rpms, if you use different rod length rods you have to use pistons for those rods. The wrist pin hole are located differently for the rod length
355REDNECK
Quote from: Jr on November 03, 2011, 06:05:03 AM
more rpm's
what is this a 283 crank in a 350 block
WHEN IN DOUBT THROTTLE OUT
