For those willing to look, 92 CPI 4.3 issues
Started by Colorado, December 22, 2011, 11:36:06 PM
doughchvy1
Colorado, I had a 95 that would do that. i put alot into mine trying to find the problem out and it ended up being the temp sensor along with the O2 sensor they were reading oppisite of each other which was throwing the timing all over the place.
Colorado
That's crazy p00. Well I hope just replacing the temp. sensor does the trick then. Far as I know the O2 sensor is factory.
==thanks
Squirell
sounds like a fuel pump.....gf blazer did the same thing. changed the fuel pump and its fine now
Colorado
That would also be cool with me. Well the fuel pressure is about 42 and the compression is low. 90-120 most cylinders. Just put in new injectors and it still only starts on starting fluid and dies once ya touch the gas. Next step in coolant sensor.  :(
42 PSI?  Needs a little more than that.  I would go with a new pump.
Colorado
#25
Ya priming it's about 60ish and running it bounces around 42. Really don't wanna do a pump but apparently that's the problem. Gotta see what the book says. Guess I'll try a coolant sensor too.
Imo  stop throwing parts at it and hoping one of them will work...very costly, unless you have the money then go ahead, but test the parts before you replace get a scanner hooked up to and see if cts is reading correctly, your fuel psi is low dont just assume its the pump, check filter and psi before filter, and also when you checked fuel pressure what was the pressure after pump primed with key on engine off. CTS could be throwing the timing off but then you need to find out about fuel psi problem
prime fuel psi key on Engine off-  60psi
Running psi- no less than 54 psi
clogged line, filter, or sock on pump can cause 10- 15 psi drop
Colorado
To my knowledge you can't connect a scanner to OBD1. It had a code on and off this summer when running but it seems gone. I put on a new inline bottle type filter when I dropped the tank and tried to fix my lack of fuel gage issue. The intank sock filter didn't look plugged at all. Dunno how to check pressure BEFORE inline filter unless I put in a filter delete fuel line....but that one was new....
Buck
the spiders go bad in them  alot under the intake  check them 25 50 bucks at  junk yard
chevv chevgal chevvv
I have a scanner that hooks up and will control computer functions as well as read codes, but easy way to test cts pull it out and hook up volt/ohm meter to it, check for oem specs.   To check psi before filter- fuel pressure tester should have an adapter that will thread into fuel line or a quick connect, If not easy to make one, self explanatory.  ;D
Colorado
Quote from: Buck on January 16, 2012, 03:05:18 AM
I just installed brand new injector poppets and put in new spider lines (both) this summer. With a newer used regulator.
My question is, does the computer read the cts in open(I think it is)  loop (a day of not running)???
O2 senosor is read in open/ closed loop
Cts is not its consntly read and adjust fuel rate per temp reading it sends to computer   its kinda like a choke on a carb   its the only way for fuel injection to choke engine     ie cts is broke and is telling computer engine is 800 degrees when its actually 45degrees it would adjust fuel and timing to be crazy lean and vice versa
Colorado
Well this morning I tested the pressure on our 98 Safari and the fuel pressure never goes below 57-8 and never over 62 so everyone who said 60 is right. So guess F.P. is my issue.  I have a buddy who still says it's timing but this shows itself..   ==doh
Colorado
Replaced the fuel pump with a Ebay special and it runs great now. ==thanks everyone.
idk if this is your prob, but it happend to me.
on the fuel pump there is a bag filter that goes on the end of it. well the bag filter came appart and got sucked up in to the pump. it didnt completly stop the pump, but stopped the flow, a lot. so i would backfire under load, and just ran like p00.
hope this is your problem, its an easy fix. wish ya luck.
Quote from: ProGrade on December 24, 2011, 05:57:17 AM
did you check the distributer gear? wear or damage is fairly common and will make it run like p00  if you didn't already check plugs and wires too.
did you check the dizzy gear?? neighbor had a late 90's 4.3 in an extended cab that ran great till one morning we was heading to pick up his old lady when her car died on her, well 1/4 mile down the road he blew off a couple teeth on the dizzy gear and we were walking
Colorado
JThomas :I replaced the sock filter with the new one that came with the new pump and I checked to make sure it was snug and on all the way.
Jay: I checked all that and it's nice and tight.
Dirt Worm
Mass air flow or map sensor would cause same symptoms, sounds like same thing my 97 jimmy was doin
looks like no one reads thru the thread.........
good to hear you got it runnin good colorado.
glad I could help  ;D
