Project Redo Rockwell/ Mean Streak / update 8/24
Started by Bowtie972, December 26, 2011, 08:03:29 PM
This project started early last spring, I had sold my 1 tons and bought a set of Rockwell 2.5 tons. Then I had surgery on my shoulder and everything went on hold.  I couldnt physically work on it and really couldnt afford to finish it.  I went back to work at the end of August, and had a whole pile of insulation that needed to be put up in barn before winter, and the furnace installed.  When I had fist started the project I went down and visited Dave, (wildtime) and bought a bunch of parts.  Now its finally time to finish this project.  I have 8" Superlift springs already, added 6" spring perches to the axles.  I did get those welded on the other day, and got my U bolts made.  Once I get my trans and T case back in and can see driveshaft angles, i have to make some shims to tilt the axles up.  Ive got to make shock mounts, redo rear ladder bars, make a torque bar for the front axle.  Im goin with Hydraulic steering also. and rear pinion brake.   Planning on keeping the 44" Boggers, 468 BBC, TH350/NP241.  Maybe upgrade Trans/T case later.
More pics.
355REDNECK
WHEN IN DOUBT THROTTLE OUT
STEUERDUKES
DRIVE FAST & TAKE CHANCES!
kEEP THE RUBBER SIDE DOWN!
Stump Jumper
Lookin great!! Can't wait for it to go to tgw in the spring
one day i hope to build me a big ole Rockwell rig.  keep the pics coming
Thanks guys, probably be next week before i make anymore real progress.  I am hoping to get the trans back in this week.  Another delay, had to put head gaskets on my kids truck.   I am hoping to take it to TGW in May, id like to make a trial run at the mounds before that, a little closer to spring.   ;D
'the DON'
ill go to the mounds with you i want to see this run . looks good
==wgm
Quote from: 'the DON' on December 27, 2011, 09:58:17 PM
Sweet!
muddnoob
Hell yeah, lookin good Tim, its a monster for sure! Im sure it will impress, it always does!  I will have to stop by and check this out,
Thanks guys!  Nothing really worth takin pics of, but I did get the trans/Tcase back in, mocked up the driveshafts.  Lookin like im gonna have to lenghten both of em.  At least I can tell now how much shimming I have to do to the rear axle.  When I get some more parts installed Ill get pics.    ==wgm
chevy.jas
chico
sweet set up looking to see it in action
Makin some progress. I couldnt get the Pinion angle i liked, so i opted for the shackle flip & longer shackles.  I added a smaller shim and im happy now with it.  Did some frame tieing in the back, 2 pieces of
3 1/2" sq tube between frame rails, and connected everything all the way back to the bumper w/ 2 x 2 x 1/4" sq tube. To save some $$, I dropped down the rear shocks instead of buying longer ones.  Rear ladder bars are done.  I fabbed my own helmet for the front axle to mount my front torque bar to also.  I also dropped down the front spring mounts 4".  So with susp and body lift its gonna have around 21' - 22" of total lift.   ;D  Next up is Hydro steering and pinion brake.
