Bud Wogger
Started by Bryank, January 15, 2012, 03:10:38 PM
jcrandell420
What's on the sidewall are tgey 12.4-24
Quote from: BAD APPLE on August 09, 2013, 09:56:24 PM
almost walked outside with a flashlight then remembered i awnsered this before couple pages back lol. they are 10.00 x 22 off them irrigation systems. only the newer ones look bigger and wider!
Quote from: jcrandell420 on August 09, 2013, 08:20:44 PM
GotMud?
holy crap you are finally on here josh! sweet you should start a topic of your chevy it's getting pretty badass!
Next Sunday finally gonna beat on this beater!
it's ready to get it's ass whooped! tomorow at Orleans!
yukonjake
beater did good.
truck did good at Frahms yesterday. things are working good only minor stuff has happened. Next week is stewarts mud bogg. Then maybe one more at my buddy joe's house and i'll call it a year. Still haven't tryed the tractors, really don't need em ;)
gonna see if the bud wogger likes it's tractors tomorow
yukonjake
Quote from: highbrid on September 22, 2013, 01:46:52 AM
Where is the bog at?
it's at Stewarts mud bog South stevenson rd crystal/stanton area
yukonjake
Hmm might have to try to get over there why didn't ya go to the one in white cloud at allers farm?
Quote from: highbrid on September 22, 2013, 02:43:25 AM
would have like too but not enough $$$. my dually gets 5mpg!
tractor tires worked great but motor lost oil pressure. sucks time for rebuild again :( 3 bogs n done
yukonjake
Understandable sucks about your motor  hopefully ya didn't hurt anything
that sucks bad pump mabye? hope its a easy fix.
it's just a real bummer. last time i rebuilt this thing it lasted 7 years. i thought it'd last longer this time! p00 i put in a forged crank arp main bolts and it plastigauged perfect. it's starting hard and can hear it squeak mains are f'd. just sucks ass at least $500 to fix her up again. if i can sell my motorcycle for $500 or trade it for a nice 350 ill put the racing small block in it but we will see.
Sounds like ur havin the same bad luck i am!
started it a few minutes ago and it had 60psi oil pressure and sounded good? i only let it run a minute though im pretty sure its still f'd. the oil pressure hasn't been good since the start. it primed good 70psi. but after starting and running it it usually 60psi idle cold and rev up to maybe 75 and warm 20-30 idle and 50 rev up. nothing like first time i built it. it would idle 70  cold and rev up to 100 and 50-60idle and still almost 80 rev warm.you wouldn't think a forged crank would make that much of a difference? i know they do expand a little when hot but nope something else went wrong. only thing i could think of was when i went to bolt up the torque converter it didn't sit against the flywheel easy. i had to tighten the bolts to get it snug against the flywheel. not sure on that though? just remember back in the day my friend had that problem. his mains got f'd up because the torque converter was pulling on the crank.
