Radiator in back?
Started by Boggen Joe, January 17, 2012, 11:39:19 PM
I recommend to every one to run to radiators if you can fit it you will wonder how you ever only ran one it makes a world of a difference
MidMichiganMudRun
Quote from: erikmud on January 19, 2012, 06:00:32 PM
How do you set yours up? do you just go in one to the next then back to the motor or do you T your lines?
Quote from: puddlejumper on January 19, 2012, 06:48:24 PM
read his post on the other pages he tells you how!
Quote from: betterbeaters on January 19, 2012, 10:13:32 PM
x2
4X4jared
Quote from: erikmud on January 19, 2012, 03:12:00 AM
well you have the two places that the front radiation go on the thermostate housing and the other on the water pump where it normally goes then there are a couple other smaller bungs on the water pump and another on top the intake
MidMichiganMudRun
O yeah guess it helps to read the whole topic...lol
Boggen Joe
This was very awesome  ==wgm. Very helpful information, hit a lot of different issues.
I'm very impressed got mud, thank you
rob69
Lets see some pics of your guys set ups. I am thinking about doing this on my ranger build.
sorry bud I got no pics for ya, I sold the truck I had it on, But when funds get better for me Im doin it on my xj. But im sure someone has some pics for ya  ;D
Newbie
Quote from: rob69 on January 22, 2012, 05:52:47 PM
x2 bc i wanna put it on my chevy
mutt truck
I put my radiator in the back of my cherokee, its right behind my seat with two elec fans and a 160 thermostat. I do jot at this time have a sheild ob it but am going to put obe in soon. It does get warm inside the rig but i took the rear window out for ventilation. I also run an electric pump... puts out something like 44 gpm.
I WILL GET SOME PIX AND POST EM SOON FOR YOU GUYS.
Quote from: mutt truck on January 28, 2012, 07:24:18 PM
How did u hook up elec. Pump on your xj? Do they make aftermarket ele. Pumps for them?
mutt truck
Quote from: xjs3667 on January 29, 2012, 05:12:25 AM
Well it has a buick big block in it so it was easy. ;D
lol ok that makes sense then
here is how i ran my two radiators, your original front one hookes up like normal, top hose to the thermostat housing, and bottom to the water pump, now with a rear radiator, there is a taped hole next to the thermostat, i threaded a bung and hooked one hose for the rear radiator there and then there is a bung on the water pumo that i ran the other hose two,  then i used 1in heater hose and ran that down inside the frame rails to keep them from getting punchered, and drilled to wholes thru the floor and ran the hoses up into the back of the bronco to my second radiator
Squirell
i got a question. why dont you just run your lower and upper hose to the back to a radiator and put a fan on it. that is how i did mine and i never had a problem. I used a stock pump and a two sticks of 1 1/2 muffler pipe and never had one problem. hell my s 10 never went above 180 with the fans on.
Quote from: Squirell on February 06, 2012, 02:42:24 PM
i run a stock pump to with no fan on the front radiator, and one on the rear and never get much hotter than 180 with a built big block so why change
Squirell
Quote from: erikmud on February 07, 2012, 03:06:21 AM
I did the same thing with a built small block and only used one radiator..but to each is their own
Every engine cools different I had a stock small block in my bronco once and I couldn't run 5 minutes with out overheating buddies got a built big block in his truck only runs one radiator, never over heats, just gotta find the right set up for what you have and how much you beat on it
