divorced trnsfercase
Started by 355REDNECK, January 26, 2012, 01:02:18 AM
355REDNECK
whats the advantages and disadvantages
WHEN IN DOUBT THROTTLE OUT
they're good for extreme driveshaft angles   ( tall lift kits )
you can run a 2wd auto trans or manual trans.............possibly easier and cheaper to find.
only bad thing I'd say is that you have one more driveshaft (between trans & T-case)........which could be a weak link
The intermediate shaft is actually pretty strong, most of your torque comes after the t case, use quality u joints and loop style yokes, and try to mount the case as strait as possible in line with the trans for less possibility of binding or vibrations
I put one in my truck because of driveline angles... The front is better but the rear got a little worse, but I'm running a short bed truck
355REDNECK
how much hp do you think one can handle
I don't think it makes a difference divorced/non as far as strength.  Less chance of splitting the transmission case tho since they are not connected.
