Tranny removal
Started by Jthomas, February 17, 2012, 02:43:06 AM
But I'm only rockin about 400hp
Quote from: ice87 on February 17, 2012, 11:38:38 PM
What the compression on the motor without the blower
12:1
6.7" pink rods
I have another set of flat top pistons for it, that would probably be better for the street and lower compression. But like I said, I'm on a time frame, so I'll just run like 3-5lbs boost. I could even underdeive the blower and run lower pounds to make me happy with MPGs.
In the boat I have a stock 454 with mild hydraulic roller cam running 9lbs on a 6-71. And it's pretty good on gas cruising alll day long. But if you hot rod it, then yea, it sucks the fuel.
ice87
Quote from: Blazin40s on February 17, 2012, 11:48:31 PM
big difference between 400hp and 800hp for a 700r4
All day long^^ ignore the stupid alll
ice87
Quote from: Jthomas on February 17, 2012, 11:49:06 PM
12:1
6.7" pink rods
if it was me I wouldn't run a blower on that motor with it having 12:1 compression
yea but if your going to save up to build the 700r4 why not save up and buy a 400th??
Quote from: OHEARN.2012 on February 17, 2012, 11:52:47 PM
Idk, that's what I'm on the fence about.
Quote from: ice87 on February 17, 2012, 11:52:06 PM
12:1
6.7" pink rods
That's what I was thinking. But that's how the motor came stock from GM (I think)
But like I said, I have another set of lower comp pistons. When we got the motor it was pretty well built from GM. Then we modified it with a little more cam, longer roller rockets, stud girdle, rods and crank.
The motor was featured in the 1976 2nd addition Chevrolet Power manual.
you could run a blower but wouldnt go over 3 psi that would bring your compression ratio up to 14:1 but then you need to run racing fuel like 110-114 octane. you dont wanna go over 12:1 on high octane pump gas.
I would advise against it but to each there own lol, Im runnin around 9-10 psi on my motor and have  a 14:1 ratio but it adds up in gas fast lol
Quote from: xjs3667 on February 18, 2012, 12:10:30 AM
Yea I was planning on keeping it 3-5Lbs. And I could change the pistons on a rainy day. But the heads are from another motor. The heads are ported, flowed, and cnc'd. Harder valve seats. Roller lifters, springs matched to the valve train.
And I know what you mean when running 10lbs WFO = empty tanks
But I chose a blower so I have that instant off the line power and boost. And hell, to me it looks cooler than p00 with the scoop and belts through the hood.
Quote from: Jthomas on February 18, 2012, 12:44:41 AM
u shud be boggin on a rainy day loll
Quote from: Jthomas on February 17, 2012, 11:58:22 PM
save up run the 700r4 for now and when u can buy a 400th buy it and build it to hold up to your motor problem solved
I'm just gunna get rid of the 700r4. Get a th400. And build the 400 up. Anyone wanna trade? Sell? Buy?
if you were closer I would probably buy that there r4 from ya :)
Quote from: xjs3667 on February 19, 2012, 04:19:38 AM
Yea, and I'm sure I would get raped on the shipping. (odd sized box, and heavy as hell)
