Methanol Injection??
Started by OHEARN.2012, February 19, 2012, 03:43:04 AM
what is it ive heard the term thrown around before but have never fully understood what it is
frdzila
I think it is just another term for alcohol injection. Meaning its just another type of fuel injection.
xjs3667
methanol injection is used on diesels, and  like alcohol injection on a gasser.
burns cleaner, less egt's, lots more power
Quote from: xjs3667 on February 19, 2012, 04:07:13 AM
can u run it on like a sbc 358 on a daily driver?? There's a place that makes kits for it
xjs3667
yes it can be done, but is usually used in combo with a blower, you have to be very careful, its very easy to explode and engine with it lol and when I say explode I mean it lol   and your going to wanna start with a low compression engine, like a 7.5:1 or 8:1,
imo go nitrous, easier to deal with, still have to worry bout blowing stuff up but not like with meth, and you can get same amount of power.
73chevytruck
they did a show on this stuff today on horse power,  they make a kit for carb motors,looks pretty cool,
http://www.snowperformance.net/stage-2-boost-cooler-muscle-car-n-a.html
72 Bogger
Quote from: 73chevytruck on February 19, 2012, 04:48:54 AM
I saw this it looked bad ass and they say it can be done in about 2 hours
drive like you stole it
rangerwheelinmike
i olny hear abought it for motors with boost i wouldent mess with it on a dd lol
halfa12pk
we run methanol injection on our sprint car. it is mechanical injection. no electronics, the only battery is a 9 volt that runs our oil light.
BAD APPLE
Its cheaper per gallon but u will burn more faster so you will be filling up a lot so in the long run its going to cost about the same as running gas, same thing with e85 and alcohol
no rest for the wicked
a 540 bbc with methanol injection and a pretty hefty blower would be fun but yea i guess the dd's outta the question
N8
The desiel injection uses a mix of methanol and water. Alot of guys use winter grade windsheild washed fluid.
I'm addicted to brake fluid, but I can stop anytime
water/alcohol injection is added at the intake. it cools the charge, and bumps up the octane. good cheep power.
Jthomas
#13
i dont know too much about it, my dad runs that alky in his boat. but from what ive heard, its alot better than fuel, thats only if your just using the vehical for play, not daily.
meth is like $2 a gal (but you burn like twice as much)
you have alot wider tune up area
a meth motor doesnt detonate
and blah blah cant remember. but if this is just a weekend banger. then go alky befor gas.
but like others mentioned ^^^ methonal injected is just another type of fuel injection. methonal = alchohal
Wild One
BAD APPLE
acually me and dad are kickin around the idea of water/alcohol injection in our boggers, snow performance offers a complete setup for around 300
xjs3667
im actually guna be installing a set up on my jeep, but I find it more fun and usually at least half the price to make your own kit  ;)  very simple to do
BAD APPLE
Yeah but the kit we are getting has the electrical stuff so it can be tuned to come on at a certain rpm and shut off the motor if it senses any problems, with a high compression engine the low octane pump gas will detonate the motor if the injection system were to fail it would be pumping just 93 into the motor so the electical stuff has a saftey feature that a self built kit doesnt
xjs3667
Quote from: erikmud on February 21, 2012, 04:18:05 AM
I hear ya im runnin 14:1 cr  yet I got a blower on there too, so only need the meth when the boost is going since as soon as I let go of throttle bypass valve opens and im back down to around 8.5:1 cr.   so Im guna have it set up so it sprays when I have boost and if it does fail I will obviously know right away from the knock and its just a matter of letting off the throttle for me  lol  but every set up is different, so good Luck with it  :)
BAD APPLE
Do you have a build thread on your jeep it sounds pretty bad ass, and I could probably tell if something goes wrong with the injection while running by the sound of the motor but I would rather be safe then sorry, already been through a couple motors don't want to risk another one
